4 banger to 5.0 wiring nightma
Old 01-27-2004, 10:44 PM
1992 schp
1992 schp's Avatar
Default 4 banger to 5.0 wiring nightma
i am swapping a '89 4 banger with automatic transmission to a 5.0 with a t-5 tranny. jesus christ what a pain. the pedals were a nightmare!!!!! anyway, i had to extend the alternator harness to the other side of the engine compartment and of course change the computor and engine harness. My question is why will my fuel pump not come on??? we straight wired the pump and the car fired right up and then went dead after about 5 seconds. hoping for a little advice before i go and tear something up. it is the 4 banger pump. hoping to run it that way til i get a little money.</P>
and oh yeah. i installed an Imperial 16" fan and an Imperial thermostatic temp switch and relay. I forgot where the yellow wire goes. from the temp sensor in the radiator there is a brown and a yellow. the brown goes to the rerlay but i forgot where the yellow goes. antbody????</P>
1992 schp is offline
Old 01-27-2004, 11:19 PM
Quik
Quik's Avatar
look at the past issues of 5.0 mustang they did the same s**t. they took a 92 notch 4 banger and threw in a efi 5.0 based motor they should be able to help you out
Quik is offline
Old 01-27-2004, 11:37 PM
86lx
86lx's Avatar
on a four cyl. car there is only one plug going from dash harness to engine harness by the brake booster usually a blue or grey plug round a v8 harness has 2 plugs if i can remember right you can use a 90/91 v8 engine harness that still has fuel relay under seat (driver) 92/93 harness had relay by mass air sensor i did a few conversions and got confused what years will work with what so i just swapped dash harness to v8 with 2 plugs in my case i've parted so many cars pulling a dash is not a big deal hope i gave you some things to look into.
86lx is offline
Old 01-28-2004, 08:53 AM
1992 schp
1992 schp's Avatar
thanks
Old 01-28-2004, 07:11 PM
1992 schp
1992 schp's Avatar
i think i will just run the entire inner dash harness to keep it intact</P>
</P>
Old 01-29-2004, 06:46 PM
1992 schp
1992 schp's Avatar
i looked this morning. i have both relays in the car. 1 under the seat and 1 under the mass air meter. where does the harness start and end??? i had a 92 5.0 and swapping to a 89 4 cylinder. i guess the relay under the seat is supposed to run the pump in my 89 and that the relay under the mass air meter is not connected at all at some point.....but where??? i wire up $250,000 boats for a living but can't wire up a freakin' $5,000 mustang . hahaha<IMG src=smileys/smiley7.gif border="0">
Old 01-29-2004, 07:16 PM
86lx
86lx's Avatar
the relay by mass air you are seeing is a/c cut off if you have harness with relay under hood there will be 2 of them 1 for fuel and 1 for a/c cut off both are located by mass air.
86lx is offline
jwog666
12-27-2021 08:09 PM
mustang0291
10-12-2015 07:55 AM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
Quick Reply: 4 banger to 5.0 wiring nightma
