hunting & surging?
Old 05-05-2003, 08:28 PM
mark
mark's Avatar
Default hunting & surging?
I own a 92 GT with these mods: ported Explorer upper & lower, 65mm mass air,shaved & ported GT40P heads (compressions about 10 to 1), E303 cam, 24 lb injectors, 190 lph fuel pump, shorty headers, no cats, mac exhaust, tremec 3550 & stock ignition (timings at 14). when I come to a stop, the cart pulls this "hunting & surging" crap, revs up, then down, up then down until it falls on its face & stalls out. Any suggestions on how to fix this???
mark is offline
Old 05-06-2003, 09:09 PM
spike306
spike306's Avatar
take apart the whole throttle body assembly and clean it out. if you have u/d pulleys then you need a bigger alternator cuase they pull from it, and you should probably lower your timing to 12. also check all of your vaccumes.
spike306 is offline
Old 05-07-2003, 05:41 PM
DougBlevins
DougBlevins's Avatar
drill a 1/8" hole in the butterfly of ur throttle body
DougBlevins is offline
Old 05-07-2003, 07:16 PM
mark
mark's Avatar
I have barely any miles on the throttle body, so its not dirty at all. I also have a 140 alternator & underdrives. As for vacuums, with the explorer intake I'm using, some don't get used, so I plugged the rest off.I also tried cleaning the mass air flow sensor already.....no help. I got new o2 sensors too. I've read other posts & it seems everyone who replies about this problem says check the idle air control & MAP sensor. Wouldn't the car throw a "check engine" light if these sensors went bad??? I tried messing with the timing for a good amout fo time, 12 seemed weak. Its at 14 now & pulls real nice. I've never heard about drilling the butterfly hole bigger, but maybe its worth a try. Thanks.
mark is offline
Granatelli Sales
01-20-2020 12:34 AM
10-07-2015 07:02 PM
MacSerio
09-27-2015 01:05 PM
lmurf60
09-24-2015 10:07 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: hunting & surging?
