Fly cut
Fly cut
with that cam you'll be ok...bmorris is right on the s/c thing...you can flycut pistons in the car. it's not a perfered method..it doesn't hurt your pistons..I use an old H/G and some playdough or silly pully to check clearances..what head or you using?...you could possible go to a 1.7 rocker
Fly cut
They are a set of stock heads with 1.94 intake and 1.60 exhaust, 3 angle cut, port and polish on intake runners, race flow valves(stainless steel) I would like to go with 1.7, but I don't want to hit the piston with the valve.
Fly cut
Originally Posted by Red5Ltr
What do you use to measure the gap and how when you have the heads mounted?</P>
</P>
Thank you,</P>
</P>
John <IMG src=smileys/smiley2.gif border="0"></P>
you use clay in the cylinder</P>
jwog666
12-27-2021 08:09 PM
