chip or dyno tune?
Old 02-04-2004, 09:30 PM
grabbem88
grabbem88's Avatar
Default chip or dyno tune?
which one is worth it? i got aftermarket/bigger everything.....dss,afrs,comp544/544-224/230 cam 24lbs rpm int. idle problems arn't bad just acts up.the only ford related sensor not replaced is my IAC...well valve.do those extenders work??? will a tune find it what is checked???
grabbem88 is offline
Old 02-04-2004, 10:02 PM
callmecobra
callmecobra's Avatar
both, get a custom burned chip man
callmecobra is offline
Old 02-04-2004, 10:49 PM
grabbem88
grabbem88's Avatar
well the place near me will burn/dyno tune for about $750.oo bones is that reasonable? i guess it is,since i dumped a truck load in my stang huh?? i hate answering my own questions.
Old 02-04-2004, 11:58 PM
86lx
86lx's Avatar
have a custom chip burned that shuts off mass air at idle and your idle problems will be gone, if i can remember who did my friends i'll let you know.
86lx is offline
Old 02-05-2004, 12:32 AM
vfast
I ♥ Acer
vfast's Avatar
you can get a tweecer rt,pms or the like...get your tune close..as it will take care of idle issue also..it's a great tool to take dyno and you don't have to chase the guy down that did your chip...also a great thhing is you can have several tunes on it for different driving conditions
vfast is offline
Old 02-05-2004, 01:33 AM
callmecobra
vfast what is a tweecer?
Old 02-05-2004, 04:56 AM
T5superduty
T5superduty's Avatar
http://www.tweecer.com/
T5superduty is offline
Old 02-05-2004, 06:55 PM
grabbem88
grabbem88's Avatar
which one is easier to understand i'm not familliar with that kind of stuff. can it tell me where i should be at? can i get a little info to understand it?
Old 02-05-2004, 08:00 PM
mkspeed26
mkspeed26's Avatar
your a/f ratio is most likely off, so i would suggest a chip or a tweezer. my choice would be tweezer and dyno tune for max hp. but then again, i would convert it to carb because it is much cheaper and easier to tune <IMG src=smileys/smiley2.gif border="0">
mkspeed26 is offline
Old 02-06-2004, 05:30 PM
619socalstang
619socalstang's Avatar
you can do a carb conversion for less than the dyno tune and the tweecer system. NEW $800 used $500
619socalstang is offline
Quick Reply: chip or dyno tune?
