problem with 93 5.0
Old 02-05-2004, 06:45 PM
bobby
bobby's Avatar
Default problem with 93 5.0
ok my dad has a 93 f150 with a 5.0. when he starts it up in the morning it will run fine and he can drive it as long as he wants. then when he shuts it off. abbout 5-10 minutes later he will come back and start it up and about 15-20 seconds later it will idle way down and die. then when he starts it back up it will run fine until u shut it back off and then do this again. does anyone have any suggestions PLEASE! help. thanks a lot. below are what have been replaced on the truck/
new fuel pump and filter
new throttle position sensor (tps)
new map sensor
bobby is offline
Old 02-05-2004, 06:56 PM
vfast
I ♥ Acer
vfast's Avatar
have you guys tried to pull any codes? alll most sounds like a coil problem but I'm just guessing...02 sensors the stock ones? might be that..something is getting heat soaked
vfast is offline
Old 02-05-2004, 07:02 PM
bobby
bobby's Avatar
we pulled some codes and found that there was no flow in the egr valve. and that the thermactor air system was innoperatable. i dont know what that means does anyone know what the thermactor air system is
bobby is offline
Old 02-05-2004, 09:18 PM
bmorrisj
bmorrisj's Avatar
smog pump...pumps air into the back of the heads and cats...
bmorrisj is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
JT76
09-20-2015 11:32 AM
vintageaion
09-08-2015 10:45 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: problem with 93 5.0
