85 5.0 carburetion
85 5.0 carburetion
Hi y'all, New to this forum, first time foxbody owner. This car has all stock OEM stuff including California type carb. Just got the car running after it set for a long time. So far, engine starts and runs OK, but I was wondering if I should put another adjustable carb on it, or should I just leave it the hell alone? Are there any simple after market changes that are helpful, or should I just stay with what I got?
I get the heebeejeebees when I see any EPA restrictions on automotive performance. Will an unregulated, similar carb add more giddyup or should I just be satisfied with what I got if it performs OK? I live at 5200 ft. elev. and I have no idea what fuel metering settings are in the carb.
the compression on these was a little low from the factory but yours is extremely low due to your elevation, milling the heads to increase compression will get you noticeable improvements but if you mill them too much then it will ping/detonate a bit at sea level.
Thanks for the input. Still cleaning the car up because of the previous knucklehead owner's neglect. Gotta do clutch and brakes before I can really see how it performs. Then I can see about mods to it based on the input I am getting. I found an 85 at the local junkyard that has a thottlebody on it. A worker there said the engine is fine but the trans is dead. What issues are involved in swapping that out for mine. Will it help performance? In days past I would be out there getting the whole engine, but nowadays I'm too lazy to take that on.
if you have 4 barrel...leave it on!! the cfi is a step backwards and not even worth the conversion......it's basically like putting a 2 barrel on....many moons ago when my 85 was CFI, I had stock ported heads, performer intake and cam to match roller rockers, and full exhaust and gears....car ran 15.4 in the 1/4, took off the cfi and performer 302 intake that had a 4 to 2 barrel spacer on it and got the car to run a 13.4 with just a swap to a performer 289 intake and edelbrock 600 carb.............also don't waste time with any mods to stock heads......price to do such vs benifit will quickly surpass the cost of a set of decent used aluminum heads.
After reading up more on these issues, I learned that what u are saying is true. If I do anything, it will be to replace the Holley (California) with an Edelbrock set up for my elevation. Still working my way up the learning curve. Thanks for the advice.
are you trying to stay emissions compliant??
