oil pressure
oil pressure
Originally Posted by seoul4cali
hmm, my stock guage doesnt show numbers. would it be correct to assume that 15 psi is the red?
oil pressure
more like 10 psi in the red
no high oil pressure can be a problem as well you can pick up foam in the pan h/v oil pump are ok in a 6 qt pan
gmkiller..man that 20/50 is heavy unless it's 90 degrees hope it's syth.
oil pressure
Yeah its only summer time when i get the stang out so its between 80-100 in the summer.Its not that big of a deal to run 20/50 except in the winter.I like running it in the summer and the motor definately likes it.Its added protection because it sticks to everything and stays where it needs to be a little longer.
ccdguy
09-19-2015 05:20 PM
