injectors
Old 02-08-2004, 09:29 PM
gorbs88
gorbs88's Avatar
Default injectors
ME again..have spark now but my injectors arent opening,,,,Lots of fuel presure but wont get f injectors to fire,,,Pls help......What controls the pulse width?????
gorbs88 is offline
Old 02-08-2004, 11:11 PM
86lx
86lx's Avatar
Default injectors
check red wire at injectors for volts,that wire runs through the whole inj. system if you look at a manual you can trace it out,check fuse link at solenoid i think inj. wiring link is blue.
86lx is offline
Old 02-08-2004, 11:42 PM
gorbs88
gorbs88's Avatar
Default injectors
Thanx man, i got it running....Was a eec relay by the ecm.....was missing....must of got pulled off when i was pullin wires through firewall....doesnt run all that good.....really rich.....i have 93 engine harness in 91 car.....someone said that i need to change all to 91 or it wont run very well, is this true???......my mass air is pluged in but i am running sd comp.....will this make it run like sh8t??
gorbs88 is offline
Old 02-09-2004, 12:57 AM
Quik
Quik's Avatar
Default injectors
you cant run a SD ecm for a MAF setup. it wont know how to configure anything. get a new computer
Quik is offline
Old 02-09-2004, 02:06 AM
gorbs88
gorbs88's Avatar
Default injectors
</P>
well that makes sense, but 86lx says he runs a 87 ecm in his 93.....sayd works just fine.....not sayin your wrong....i just ran this ecm cause i dont have a MA one yet....have to find one......</P>
gorbs88 is offline
Old 02-09-2004, 02:59 AM
Quik
Quik's Avatar
Default injectors
his ecm could of been modded:dunno: but if it runs it might not be running correctly. or his computer really is a MAF
Quik is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: injectors
