gt-40 engine?? what you think good for a small budget??
Old 02-22-2006, 03:58 PM
swiftfox90
swiftfox90's Avatar
Default gt-40 engine?? what you think good for a small budget??
i was thinking about getting the ford racing gt-40 engine i have a really tight budget but my oil pump went and its a waste to put the engine back in the car with 100k miles on it so i had some people tell me that this was a pretty good deal, what you guys think??
swiftfox90 is offline
Old 02-22-2006, 06:28 PM
88BlueGT
88BlueGT's Avatar
Default RE: gt-40 engine?? what you think good for a small budget??
Post a link....
88BlueGT is offline
Old 02-22-2006, 06:53 PM
preciousroy
preciousroy's Avatar
i have the crate engine with the x303 heads and b cam in my 91lx, its reliable, powerful, and sounds excellent. the only problem with crate engines from ford are they use hypereutectic pistons, not the best choise if your looking for a power adder in the future
preciousroy is offline
Old 02-22-2006, 07:38 PM
gspfunk
gspfunk's Avatar
how much? Do you need a long block or just a short block? Look at DSS, Coast High Performance, and others. You can get a short block for under $2.2k depending on what you want.
gspfunk is offline
Old 02-23-2006, 12:49 AM
swiftfox90
swiftfox90's Avatar
http://www.jegs.com/webapp/wcs/store...0763&langId=-1
heres a link to the engine
Old 02-23-2006, 02:08 AM
bmnlsc
bmnlsc's Avatar
ORIGINAL: swiftfox90
This is what the motor looks like out of the actual crate..
I cannot say anything bad about this motor. It runs flawlessly. I replaced the GT-40 heads with AFR 165's and retarded the cam 4 degrees to give me more on top end. I have additional mods as well. If you wish to go with a power adder, dont hesitate to do so. Even though these crate motors come with the " hyper-pathetic " pistons, it is all in the tune. I have the Vortech S-trim with 8 lbs of boost and will be upgrading to 11 lbs shortly, with a Chip and Tune of course.
Now she looks like this:
With a simple backyard tune (running fat), I dyno'ed at 390/397 to the tires. I am expecting 475+ after the tune.
Good Luck!
BMN
bmnlsc is offline
Old 02-23-2006, 10:12 PM
r.barn
r.barn's Avatar
I've been looking at doing the same
but just came up with this alternate..........
you get the top end kit from here
http://www.latemodelrestoration.com/...NGINE~MCYLHEAD
then you get a short block with better forged pistons from
http://www.coasthigh.com
for about the same $3,500 you get the same engine
but with the extras of.........
Cobra Intake manifold and
High permance forged crank and pistons.
r.barn is offline
Old 02-24-2006, 12:38 AM
tinman
tinman's Avatar
Ford has 12/12 warranty on the crate motors now.
Check at the dealer.
I think they would be pretty good deal if you want mild performance.........
tinman is offline
Old 02-24-2006, 12:48 AM
gspfunk
gspfunk's Avatar
ORIGINAL: r.barn
I agree w/ you about taking that route, but I'd go w/ a different top end kit. On the 50resto link if you scroll to the bottom, they have the trick flow top end kit for $2150 and then go w/ the CHP 306 short block for $1699 (I think the GT block is tappet instead of roller)==$3849
gspfunk is offline
djbigskrilla
09-20-2022 01:04 AM
Gary Ugarek
63
12-11-2015 02:01 PM
Gary Ugarek
08-26-2015 08:41 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
Stilz
08-19-2015 06:17 AM
Quick Reply: gt-40 engine?? what you think good for a small budget??
