82 5.0. cam specs
82 5.0. cam specs
anyone know what are the cam spec on the 82 5.0L?? all i know its a 2v marine cam with a double roller, but i want to know what is the cam duration, and lobe sep, and if it was a hyrdaulic or mechincal Flat tappet?? thanks any advice welcome
RE: 82 5.0. cam specs
Ok here is what 82 got.....
Firing order: 1-3-7-2-6-5-4-8
Cam drive chain: double roller, width is .875in
Rocker arms (type and ratio): stamp steel nonadjustable; 1.60:1
Lifter type: Flat hydraulic
Cam Spec's
Event Intake Exhaust
opening 15Deg BTDC 68deg BBDC
closing 65deg ABDC 26deg ATDC
Duration 260deg 274deg
overlap- 41deg
lobe/valve lift .260in./.416 in. .274in./.444 in
lobe center 115deg 114deg
part number----- D3OE-6250-AA
Hope that helps some..... Nelson
Cam Spec's
overlap- 41deg
