Last edit by: IB Advertising
Browse all: Lighting Guides
- Ford Mustang Gt 1996 to 2004: How to Adjust Headlights
Step by step instructions for do-it-yourself repairs
headlight adjustment???
#22
RE: headlight adjustment???
ORIGINAL: 86 5.0L
four eyes ftmfw
didnt know MD sucked that bad at inspections [&:]
four eyes ftmfw
•Steering system
•Wheel alignment
•Suspension
•Brake system
•Wheels / tires
•Fuel system
•Exhaust system
•Bumpers
•Fenders
•Lights
•Electrical system
•Mirrors
•Glazing (windows)
•Wipers
•Hood / catches
•Door handle latches
•Floor / trunk pans
•Speedometer / odometer
•Driver seat
•Safety belts
•Motor mounts
•Gear shift indicator
•Universal and CV (constant velocity) joints
•Emissions equipment
#24
ORIGINAL: 86 5.0L
[&:] almost like Cali
course we pay off the inspection guy [8D]
#25
ORIGINAL: 91hatchgt
I have never had to have a car inspected like that in Cali... Only smog, and they only look under the hood and at the exhaust, they could care less if I had a bad wheel bearing or sun baked headlights....
ORIGINAL: 86 5.0L
course I still pay off the smog inspection guy[8D]
#26
ORIGINAL: 86 5.0L
*sigh* that was my attempt at sarcasm, hence the freaked out smiley [&o]
ORIGINAL: 91hatchgt
ORIGINAL: 86 5.0L
#27
I have three piece headlights and it is much easier to first remove the outside marker lens with 2 nuts, then remove center headlight lens assembly with three nuts. Its now easier to turn the three adjusting studs, two are hexagonal and one adjuster is round smooth, use vise grips on this one and adjust the adjuster studs so the center headlight fits flush all around with the outer marker lens and inner lens, you can simply put the headlight in, then the outer lens in temporarily by holding in with hand pressure then see how flush all around it looks with the inner and outer lenses, it takes a few times popping the center headlight in and out and adjusting until it looks flush with the other 2 lenses and with my mustang this gets the lights aligned and more importantly looking better.
