Last edit by: IB Advertising
Browse all: Lighting Guides
- Ford Mustang Gt 1996 to 2004: How to Adjust Headlights
Step by step instructions for do-it-yourself repairs
headlight adjustment???
ok, plain and simple, how do you adjust the headlights... like where they point... mine are off and are in desparate need of alignment...(need aligned because they are new, the light housings and adjustment plates, its all stock parts just all new...)
RE: headlight adjustment???
The adjuster is behind the headlight. There should be a couple longer bolts on each headlight, 1 adjusts the up down and the other adjusts the left right movement. I would park close to a wall or garage at night and adjust. Or sebd it to a shop there is a aiming tool.
There are small screw looking things that are on the back of the headlight. I believe there are three per headlight. Two on the top and one on the bottom. To adjust you just turn it either way it has to go. All you need is a 5/32 socket wrench and just play with it until you have the desired alignment.
right, but if you look at them again, 2 look like a socket MAY work... and the other is compleetly round... its like thaton my new ones, and on my stock ones.... i know what all the parts are... i just put em in at 11pm [:@]lol. but yea... 5/32 socket... ill see if it works out... i was just making sure i wasnt gonna hve to remove them and unscrew the screws by the heads... that are attached to the light... thatda been a bitch
na its not that... i have brandnew ones... there like that... only one on each side... and the same one on all 4(2 new, 2 old)... its deff made like that... idk... guess ill go toy w. it soon... how do yall suggest to line them up relativly close... like how far from a wall should i park and how should they point... besides straight, lol... thanks guys
Dime, this is to get thru inspection right? Don't worry about the aim, they will have to check and aim them as part of that process. They should not charge you more than .25/labor hour to do it. How long has it been since it was inspected? Seems like a while ago.
well its a new car for me(goin on 2 months now). so to get it tagged i needed to get it inspected, obviously. went the 1st time and they tried to adjust them and they said they couldnt get them to move, that they were frozen up... prob tru, because the screws were bent some(front end accident, before i got the car, no probs tho, so im not upset bout that) so i bought new ones along w. new housings because they were too yellow, which was an excuse to get clear corners anyway... but yea... thats why there outa alignment... cuz its all new shyt up there. im more concerned w. driving it at night, there pointing down...its bad. i have to to 40 tops just so i dont get to suprised by anything
o, and btw... i just noticed, us tools all rock white stangs, lol. and its a vert(sskiller), hatch(me) and coupe(you, obv)... thats some funny **** right there[8D]
ORIGINAL: dimebag
Now, not sure if you know this but you only have 30 days and 1000 miles to have the car reinspected. If you go over that, it has to be completely inspected again and you pay the full fee.
