how to prevent hood flying open?
well i am getting down to the last stages of the build and i need to decide if i am going to put my hood pins back in. it looks so much cleaner when they are not installed. i would really like to not use them but how do i prevent my hood from popping open on the highway? will just the latch and safety latch be enough?
RE: how to prevent hood flying open?
If your factory latch is properly adjusted and the secondary latch is working, you have nothing to worry about. I don't have hood pins and have been trouble free for 4 years now.
ORIGINAL: PRO50SC
you just jinxed yourself...
From what I gathered if the hood has a steel latch like the factory one then you're okay without hood pins, if it doesn't i guess the latch has been known to rip through the fiberglass latch part on the hood... I wouldn't trust fiberglass to hold my hood down.
5 yrs of using the original OE latching mechanism on a fiberglass hood and I've never had a problem.
But then again when I close my hood and I always double check to make sure the hood is locked and closed.
ORIGINAL: cleanfitty
ORIGINAL: PRO50SC
