An S/C Perdicament
Old 09-29-2007, 10:07 PM
jthorn9
The Godfather
jthorn9's Avatar
Default An S/C Perdicament
OK, quick question, what is the difference between ball driven S/Cs and gear driven, in other words how do they work? I think I may know, but I really don't understand how either works, and how much better one is over the other. I know the ball drivens were replaced by gear, but would a rebuild ball driven kit still be worth it, such as a Paxton?
jthorn9 is offline
Old 09-29-2007, 10:08 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: An S/C Perdicament
you mean belt driven VS gear driven
gear driven are often loud and screachy, and typically have complex oiling systems
belt driven, like a powerdyne... often break
AdderMk2 is offline
Old 09-29-2007, 10:20 PM
jthorn9
The Godfather
jthorn9's Avatar
OK, but I swear I saw bearing driven somwhere.
jthorn9 is offline
Old 09-29-2007, 10:28 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: jthorn9
Bearings are a rotating part, not a drive part. The driven gears rotate on/in the bearings
PRO50SC is offline
Old 06-10-2010, 08:48 PM
69fury
69fury's Avatar
not to bring something back from the dead, but just incase someone is researching for some tech:
BALL driven superchargers exist- the Paxton SN series uses 5 one inch ball bearings in the same manner as an automatic planetary transmission. instead of gear teeth, they rely on friction and slipption by being squeezed in between the races in the case halves and are self contained lubricated by ATF.
They get real hot, but come with a hollow dipstick connected to a pump and tranny cooler, have a 4.44:1 step up ratio so they get on boost quick, and are rebuildable at home. Mine is apart because the previous owner overspun it without a big enough cooler, and smoked the fluid.
The VR4 was the king of these and is good for about 15lbs of boost, 1500cfm in a small package, at 45,000 rpm impeller speed. Mine hit 62k and didn't explode, but there are billet impeller wheels rated at 65,000 which are soon to be back in production.
any SN 92,93,2000, or GSS can be upgraded to a VR4 by switching the impeller, and intake cover. 4 inch intake opening.
VR4 impeller:
brass ball carrier is turned by pulley, which causes the ***** to spin against the outer races, which speeds up the drive spindle in the center of the unit. You can also see the internal oil pump and anti-rattle spring:
one of the outer races is pinned in this aluminum disc:
other case portion with opposing ball drive race pinned in place:
69fury is offline
Soldier GT
08-12-2015 03:46 PM
94Cbra
10-08-2004 07:00 AM
RollinThunder
09-16-2004 01:42 PM
iiiGTiii
08-26-2004 03:07 PM
RollinThunder
05-17-2004 01:06 AM
Quick Reply: An S/C Perdicament
