Emissions in PA
RE: Emissions in PA
ORIGINAL: 5.0L RiCE EATER
My car currently has cats on it, any one here from PA and would know if the car would pass emissions if I took them off and just welded straight pipes?
RE: Emissions in PA
There is a section in the Clean Air Act of 1979 concerning “tampering,†which makes it illegal to modify or remove any component designed to reduce or control exhaust emissions, including intake or exhaust noise. Removing the catalytic converter on a car, or a new motorcycle constitutes tampering.
Violating this anti-tampering law opens you up to a fine of up to $10,000 per occurrence . An occurrence is logged each and everyday the modified vehicle is operated on public streets. That means a possible fine of up to $10,000 per day
RE: Emissions in PA
ORIGINAL: Importssuk
go to an auto auction in your area and buy yourself a beater car for $500. if you put 5000 miles or less on the car between inspections, you're emissions exempt in pa and you can run straight pipes if you want. or, if you wanna be really sneaky about it, you can remove the speedo gear from the trans and your odometer will stop counting and keep yourself under 5000 miles . you'll have to get used to driving w/o a speedometer though. not that i've ever done this myself [&:]
RE: Emissions in PA
Isn't pre-1996 just a visual? Which means the cats would just have to be there, not nessacarily be in function. So hollowing out the cats would be "legal" [&:]
