Radio wiring question...
Old 11-04-2007, 10:28 PM
cleanfitty
cleanfitty's Avatar
Default RE: Radio wiring question...
Not behind, but the plug is tied up inthe dash. Look for a zip tie looking thing that is holding a bunch of harnesses together. (sortof uderneath the a/c controls)
cleanfitty is offline
Old 11-04-2007, 11:40 PM
maiello2169
maiello2169's Avatar
you just need to turn on the stock amp....hook up the blue/white wire on the other harness.
maiello2169 is offline
Old 11-04-2007, 11:47 PM
cleanfitty
cleanfitty's Avatar
ORIGINAL: maiello2169
I don't think it will work, the premium sound head units are a sort of line level signal going to the factory amp, and you will be feeding the factory amp with alot more wattage and the non premium units have built in amp circuits to directly power the speakers. The wiring is different.
Just looked at the diagram for the prem sound, and from the factory head unit there are less wires going to the amp, so it is a propreitary wiring. Just use the other plugs, which will bypass the amp, and let the new radio power the speakers and there shouldn't be any problems.
Old 11-05-2007, 01:23 PM
kura
kura's Avatar
Go into the audio/visual section on MF. There's people there who'd do you wonders.
kura is offline
Old 11-05-2007, 04:45 PM
maiello2169
well as far as i know...the amp is under the passenger seat, so unless he wants to rewire it from there, i dont know what else to tell you. i have mine wired through the stock amp...it works fine. its just hard on it.
Old 11-05-2007, 08:26 PM
jhall01
jhall01's Avatar
The amp in my car is under the passenger seat. every one that i have hooked up had a blue and white wire that had to be together or it wouldnt work. i couldnt hear any sound even though i had all of my speaker wires. all the harnesses have had a blue and white wire atleast all the ones ive seen.
jhall01 is offline
Old 11-05-2007, 10:51 PM
ttocs
ttocs's Avatar
on the fox bodies in my experience the bypass hrns in up behind the glove box. Follow the hrns you have back and you will find it. Disconnect it from the other hrns(the amp output) and pull the hrns that you can plug your end into down to the radio and you are done.
page 2 of my sig shows the bypass hrns on my 94gt. It is in a different location on the sn95 but then hrns looks the same and works the same.
ORIGINAL: cleanfitty
ttocs is offline
Old 11-06-2007, 12:31 AM
cleanfitty
cleanfitty's Avatar
Thanks ttocs... that is very similar... thanks for the pics,
And jhall01, your ride must be a 93, as those had the factory amp under the passenger seat.
Old 11-06-2007, 12:35 AM
jhall01
jhall01's Avatar
nope my ride is a 90
jhall01 is offline
Old 11-06-2007, 12:42 AM
cleanfitty
cleanfitty's Avatar
ORIGINAL: jhall01
Say what??? are you sure?? did someone maybe convert it to a 93 with a factory cd player?
Quick Reply: Radio wiring question...
