Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-09-2008, 01:34 AM   #21
xxxmustangtxhc
Vehicle: 1990 5.0
Send a message via AIM to xxxmustangtxhc
Default RE: Bad Boys of the 5.0 Section
308 ci
KB FORGED PISTONS
MANLEY RODS
STOCK CRANK
AFM B-451 CAM
MOROSO 7 QT. OIL PAN
TF PUSHRODS
COMP CAMS DUAL VALE SPRINGS
RHS ALUMINUM HEADS
COMETIC HEAD GASKETS
FMS 1.6 INTAKE 1.7 EXHAUST ROLLERROCKERS
TYPHOON POLISHED UPPER AND LOWER
130 AMP ALTENATOR WITH MARCH BRACKET
FMS 2 CORE ALUMINUM RADIATOR
32oz GATORADE FRUIT PUNCH OVER FLOW
SPAL DUEL 11IN FANS
BBK UNDERDRIVE PULLIES
MSD 6AL
FMS WIRES
BBK 70MM THROTLE BODY
FMS FUEL PRESSURE REGULATOR
42LBS INJECTORS
WALBRO 255 INTANK
VORTEC TREX INLINE
TREADSTONE TURBO KIT
TURBONETICS T-62 TURBO 12LBS BOOST
TURBONETICS EVO 35MM WASTGATE
3 IN SINGLE EXHUAST BULLIT MUFFLER
90MM LIGHTNING MASS AIR
3 CORE INTERCOOLER
QA1 TUBULAR K-MEMBER
MAC DRAG LOWERING SPRINGS
STEEDA ADJUSTIBLE UPPERS
UPR LOWERS
MAC SUBFRAME CONECTORS
LINCOLN MK7 BRAKE CALIPERS
POWERSLOT DRILLED AND SLOTED ROTORS
GT500 WHEELS
HID HEADLIGHT KIT
498 RWHP 510 RWT
[img]local://upfiles/85719/CF1D95509EC84F8BAD793D8948E5BC94.jpg[/img]
[img]local://upfiles/85719/B47791A0BAFD4D2D8258AD9867E0A0DF.jpg[/img]
__________________
5.0T
almost have everything, to long to list.
xxxmustangtxhc is offline   Reply With Quote
Old 01-13-2008, 01:20 AM   #22
nmerrill
Send a message via AIM to nmerrill
ok, 91 gt, trickflow HCI, vortech s-trim 12#'s,AFM water/meth, all supporting mods, edge 3600 stall, eibach drag springs, lakewood 90/10's and 50/50's, draglite skinnies and fats, mt et streets, what else.... waiting for tune, estimating ~450 RWHP, and 11.30's
On the dyno
Pre blower
Why wont my pictures work anymore?
__________________
For Sale>>>>
nmerrill is offline   Reply With Quote
Old 01-23-2008, 01:20 AM   #23
militarymustang88gt
88 gt
fiberglass fenders/hood
306 8.5:1 e7's
b303
solid motor/trans mounts
75mm maf
edelbrock performer upper/lower
holly fpr
ac delete
aluminum radiator
full msd ignition
battery relocation
mac longtubes
bbk o/r h pipe
40 series flowmasters dumped
tremec 3550
pro 5.0 short throw shifter
spec stage 3 clutch/pressure plate
aluminum driveshaft
lakewood upper/lower control arms
bbk drop springs
bbk subframe connectors
rear seat delete
auburn posi
3.73's
scat seats
__________________
quote from 92civy:
Ohhhh Reallyyyyyyyy, Based on 95% of you posts/questions the the evidence is CLEAR, You are an IDIOT!
priceless
militarymustang88gt is offline   Reply With Quote
Old 01-23-2008, 10:39 PM   #24
ZachW04Stang
Send a message via AIM to ZachW04Stang
87 Mustang GT, BEST ET:
Stock Speed Density Computer
190k mileshort block
GT40P heads
Comp XE270HR-14 Cam
Trickflow Street Heat Intake
Ford Racing 65MM TB and Spacer
BBK 1 5/8 longtubes
BBK O/R H Pipe
NX 2 Stage Plate System only 1 stage used, 100 shot.
2 Chambered Flowmasters Dumped
UPR Solid Lower Control Arms
UPR Double Adjustable Uppers
UPR Front Coil Overs
QA1 14-150 Springs
New Motor
306 cu roller block
Machined Crank and rods
Speed Pro stock replacement pistons notched for larger valves andcams
Roush 200 Iron Heads (Windsor Sr)
Ford B Cam
Trickflow Street Intake
BBK 75mm TB & Spacer
Pro Comp 1.6 Roller Rockers
BBK 1 3/4 Longtubes
AFM N/A Powerpipe
Pro-M 77MM Bellmouth Mass Air Meter
__________________
84 Mustang SVO
86 Mustang GT
http://www.youtube.com/86zach
ZachW04Stang is offline   Reply With Quote
Old 01-23-2008, 11:54 PM   #25
1991LX5.0
91 LX
100% stock 70K mile shortblock
Canfield 195CC heads with 65CC chamber
custom grind jay alan cam .563/.566
vortech A trim supercharger with 8 rib set up 8psi
accufab 75mm throttle body
trick flow 1.7 7/16in stud mount rockers
trick flow track heat intake
42lb injectors with C+L MAF
mac shorty headers
mac prochamber
summit springs
Tremec TKO600
centerforce DF clutch
3.55's
450rwhp/460rwtq
__________________
TKO600, Canfield 195CC heads, custom ground cam, track heat intake + vortech A trim at 8lbs
450rwhp/460rwtq
1991LX5.0 is offline   Reply With Quote
Old 01-31-2008, 11:44 PM   #26
black_89gt
this is my baby, i prefer looks first over power and speed. so my car has new paint, and wheels, other than that, i have a cai, and short throw shifter...pretty basic set up
__________________
* 5-LUG SWAP DONE!!!!
"Don't let them get you!"
black_89gt is offline   Reply With Quote
Old 02-13-2008, 12:19 AM   #27
FuzzyDiceRule
FuzzyDiceRule's Avatar
Vehicle: 1992 Ford Mustang
1992 Ford Mustang GT 5.0
Engine and Exhaust:
CAI of unknown origin
FRPP unequal shortys (soon to be replaced with JBA ceramic shorties)
Carsound Catted H
Mac Pro dumps (want to ditch and get SLPs, or something)
Suspention:
Koni adjustable coilovers with an aggressive rake
5 lug conversion with slotted and plated SSBC cobra brakes
BULLITTS
MM full length weld in subframe connectors
Misc.:
UPR Blue Thunder Short throw (SUCKS, getting an MGW as soon as i rake in some cash)
Edit, sorry about that jasper, i thought it said MINIMUM of 2 pictures....
__________________
92 Mustang (blew engine, hoping to replace as daily with a terminator, but until then its getting a 306)
69 Mach 1, 351, TKO-600
71 chevelle, 454 BBC (hoping to sell for lotta caesh to fund terminator)
454ci club- member #2
FuzzyDiceRule is offline   Reply With Quote
Old 02-13-2008, 09:11 PM   #28
5.0kid
5.0kid's Avatar
Vehicle: 1992 mustang lx sc
Send a message via AIM to 5.0kid
ENGINE AND EXHAUST
302ci
475rwhp/425tq
Ford Racing Performance Parts gt40 crate motor
TrickFlow street heat upper and lower intake
gt40x heads
b303 ford cam
march underdrive pulleys
bbk equal length shorty ceramic headers 1 7/8 In.
bbk o/r h-pipe 2.5in
flowmaster 40 series
chrome tips
Vortec s-trim (high squeel) 13-14 psi
42lbs injectors
steel braided fuel lines
255lph fuel pump
AFM Power Pipe
C&L 76mmMAF
K&N filter
a/c, ps still operative
MSD 6al btm with boost retard set to take out 1 degree perlb of boost
MSD blaster Coil
Ford racing 9mm Plug wires
MSD Cap and Roter
timing set a 29 degrees
altima gold battery
COOLING SYSTEM
Fluidyne aluminum radiator
Stock Clutch fan
Drivetrain
Zoom Stage Two clutch
fidanza aluminum flywheel
Tremec Tko600
urethene trans mount
adjustable cross member
Pro 5.0 Shifter with short stick
aluminum drive shaft
8.8 rear detroit locker true trac diff
Moser 31 spline axles 5 lug
Wilwood disk brakes with park brake
T/A rear end girdle
Swarr bar bolt-on.
precision gear 3.73's
Suspension urethene bushings all the way around
rear
UPR adj. upper control arms
mega bite jr. lower control arms
eibach drag springs with air bag
strange 10 way adjustable shocks
welded in subframe connectors
front
eibach drag springs
strange 10 way adjustable struts
stock k member.
Wheels&Tires
Nitto 555r rears 245/55/16(moving to m/t et streets in the spring)
Nitto 455nt front 245/55/16
A.R.E. 8in.rims came with car (those are the ones with pics im still deciding on what 5 lug rims to get since i did the 5 lug disk brake conversion this winter)
Exterior
Saleen wing
Stock Calypiso green paint
blue oval industires clear head lights with black back ground
Some after market euro style tail lamps with black back ground
Police interceptor badges on rear, and liscense plate frame.
ASC sun roof
cobra fender emblems
Interior
Black interior
black gt seats cloth
cobra emblem floor mats
Auto Meter heater center guage pod with oil pressure and water temp gauges
Auto Meter column 2 gauge pod with fuel pressure and 20 psi boost gauge
UPR white faced tach and speedo
custom mounted shift light on top of the steering column
Hurst shift boot
Limo tint on quarter windows and rear window
stock steering wheel
Sound
Kenwood deck w/ i pod attachment
Kenwood speakers all the way around
best time to date
11.83 at 120.11mph
that was before the rear end was fortifed with the truetrac, axles, disk brakes, rear end girdle, swarr bar, and before the springs and shocks were put in. also was leaving at idle.
I am looking for low 11's by this summer. Tell me what you think!
__________________
92lx frpp 5.0 gt40, vortech s-trim 14# Mighty mite m2 c4, Trickflow track heat, 4800 tct stall, 3.73 rear gears, true-trac, moser 31s,Wilwood drag brakes, strange 10-ways on all 4, weld prostars, M/T's & skinneys, Team Z Motorsports front k member kit and coilovers, eibach drag springs dual airbag
best Et-10.96
best mph 123.60 still got some in it. leaving it in the 60'
3145lbs with driver
Winter objective:10point,mini tub, team z rear suspesion, kirkley seats, 29.5x12.5 m/t et streets
5.0kid is offline   Reply With Quote
Old 02-21-2008, 11:49 AM   #29
wadman1
this car is far from done. but i thought you might enjoy taking a look.
x
x
[ul][*]My 1995 Mustang[*][*]ENGINE[*]347 stroker is going in[*][*]IGNITION[*]Car Also Has Painless Wiring For 89 Electronics[*]Has Anderson Switch Panel[*]Wired For Electric Water Pump[*]Electric Fan[*]Line Lock[*]Battery Relocated To Trunk 1 Gauge Wire[*]Flaming River Big Battery Switch[*][*]EXHAUST[*]Bassini off road x pipe[*]Flowmasters[*][*]DRIVETRAIN[*]8.8 Rear With 3.73 Gears[*]33 Spline Moser Avxles[*]33 Spline Strange Spool[*]Ta Girdle And[*]Stud Kit[*]New Bearings[*]Seals[*]Tubes Welded[*]Rear Has 9" Ends[*]Safety loop[*][*]TRANSMISSION
[*]not in yet
[*]Tremec TKO[*]Tremec bell housing[*]McCloud clutch[*][*]SUSPENSION[*]Front Suspension Anthony Jones K-Member[*]A-Arms[*]Coil Overs Tokico Adj. Drag Struts[*]Upr Caster Camber Plates[*]Upr Coil Overs front[*]Flaming River Manual Rack Kit[*]Lakewood 50/50 Shocks[*]With Coil Over Kit rear[*]Torque Boxes Are All Reinforced With Wild Rides Battle Box Kit[*]Rear Has Double Adjustable Upper Control Arms And[*]Mega Byte Jr Lower Control Arms[*]Steering Shaft[*][*]EXTERIOR[*]New Blue Paint[*]Real Saleen Ground Effects and Wing[*]Cobra R Hood (Cervini)[*]New Head Lights[*][*]WHEELS[*]Not yet[*][*]BRAKES[*]Front and Rear Cobra Disc Brakes[*]Braided Brake Lines[*]Crossdrilled Slotted Rotors[*]Line lock[*][*]INTERIOR[*]B&M Hammer Shifter (coming out)[*]New Black Carpet[*]No Factory Gauges All Auto meter[*]Fuel Level[*]Speedo[*]Tack[*]Shift Light[*]Low Oil Warning[*]Engine Temp[*]Trans Temp[*]Oil Temp[*]Boost/Fuel Pressure[*]Voltage[*]Oil Pressure[*]Braided Line For Oil Pressure Gauge[*]Has New Ignition Switch[*]New Carpet In Trunk[*]Door Locks[*]New Power Trunk Release[*]New Trunk Lock[*]Sill Plates[*][*]AUDIO[*]New Alpine Radio[*]Polk Speakers[*][*]FUEL[*]Aluminum 15 Gallon Fuel Cell[*]Fuel Level Sending Unit[*]Roll Over Vent[*]All Braided Fuel Lines Are In Car #10 Feed #8 Return Fittings[*]All Attached Just Need Pump and Regulator[*][*]SECURITY[*]Not yet[*][*]ENGINE BAY DRESS UP [*]Painted and cleared[*][*]EXTRAS[*]Roush Tool Kit In Trunk[*]Sub Frames Connecters Welded In[*]Wired For Trans Brake[*]Pia Headlight Bulbs[*]All New Bulbs /Fuses/ Heater Core/ Headlight Switch New Parking Brake Cables[*]Under Car Is Also Pained Same Color And Clear Coated [/ul]
__________________
wadman1 is offline   Reply With Quote
Old 04-23-2008, 08:58 PM   #30
5.0 85 GT
1994 Mustang Gt
[ul][*]148k miles[*]Cam[*]BBK cold air intake[*]UPR catted x[*]Flowmaster catback[*]chip[*]loudest car at my school and proud of it[*]FUTURE MODS[*]3:55's or 3:73[*]Intake[*]Headers[*]Possibly a nice old kenne bell
[/ul]
__________________
Big Snake, Little Bite...Full Bolt-On 97 Cobra, Bored .30 over...Need Kenne Bell
-1986 IROC-Z-SOLD
-1985 GT T-Top-SOLD
-1994 GT-SOLD
-2002 GT-SOLD
-1997 COBRA-LOVE!!
-1988 Mercury Cougar Bostonian, 5.0 60k Mile Peach
-1985 GT-Carb'd Special, Bolt on's and a t-5 n Sunroof!
-1993 Ford F-150 4.9I6 5 Speed-WON'T DIE
5.0 85 GT is offline   Reply With Quote
150, 2556015, 347, atrim, density, drag, draglite, mustang, nos, speed, supercharger, time, tips, tuning, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
