Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-07-2008, 02:31 PM   #31
ruger311
Default RE: Bad Boys of the 5.0 Section
I guess ill be forced to put mine up on here, here is the rundown
1989 Ford Mustang GT Convertible
Engine
347 Stroker Dart Iron Eagle 4 bolt mains
Scat Forged 4340 Crank
Scat Forged 4340 H-Beams
JE Pistons 8.5:1 Compression
Comp Cams XE282HR camshaft
[/align]Comp Pro Magnum Hyd Roller Lifters
Comp Valves/Guide Plates/Springs/Retainers/Lock/Pushrods
Speed Pro Plasma Moly Rings
ARP bolts
Professional Products Harmonic Balancer
Moroso 7qt Oil pan
Clevite Bearings
Melling HV Oil Pump
Fidanza Flywheel
EPW 1.6F Roller Rockers
Racing Head Service 200cc 64cc Heads
Cobra Valve Covers
BBK Underdrive Pulleys
New water pump
New power steering pump
Cometic Head Gaskets
[/align]
[/align]Power Adder
[/align]HP Performance Stage 3 T-76mm Turbo System 11.75#s
Cooling
Northern 2 core Aluminum Radiator
Flex-a-lite Black Magic Extreme Fan
Intake
Edelbrock Performer 5.0 RPM II
Accufab 75mm Throttle Body Blank EGR
PMAS 3.5" Pro Tube
Siemens Deka 60# injectors
Stock Fuel rails w/ BBK FPR
Autometer FP guage
[/align]Fuel
[/align]Aeromotive A-1000
[/align]Aeromotive 10micron and 100micron Filters
[/align]Aeromotive 1000 regulator
[/align]Aeromotive fuel rails
Tuning
Dyno Tuned
SCT burnt chip
Ignition
MSD Digital 6 Plus
MSD HVC II coil
Stock Distrbutor
Accel Cap and Rotor
New Ignition Module
Taylor Plug Wires
Autolite 24 sparkplugs
93 Cobra G3 Alternator Conversion
93 Cobra High Torque Mini Starter
Optima Red Top Battery
Exhaust
[/align]3.5" downpipe to full 4" straight pipe dumped outside before passenger tire
New O2 Sensors
Transmission/Driveline
Tremec TKO600
Steeda Tri Ax Handle
Mcleod SFI Bellhousing
SPEC stage3+
FRPP Aluminum Driveshaft
Driveshaft Safety Loop
Stock 8.8" Housing
3.55 Gears
Eaton Pro Posi Locker
Moser 31 Spline Axles 5 Lug
Moser C-Clip Eliminators
21 tooth speedo gear
BBK adjustable clutch cable and quadrant
Suspension
Maximum Motorsports Road and Track Box
MM Strut Tower Brace
MM Full Length Subrame Connectors
MM Panhard Bar with Aluminum Rod
MM Heavy-duty Rear Lower Control Arms
H&R Race Springs
Bilstein front struts
Bilstein rear shocks
MM Caster/Camber Plate
MM Urethane Pinion Snubber
Rear spring isolators
Solid Steering Shaft
MM Aluminum Rack Bushings, center drilled
Front Swaybar bushings
Front Swaybar end link bushing kit
Front control arm bushings, urethane
SN95 Front Spindles
New Hubs
New Ball Joints
MM 6pt Bolt/Weld In Roll Cage w/ Swing out door bars
UPR Tubular K-Member
UPR Tublar A-Arms
UPR Coil Over Kit
UPR Bumpsteer Kit
Eibach Coil over springs 250# rate
Exterior
Cervinis Heat Extractor Hood (coming soon)
Saleen Wing
Shorty Antenna
Wheels and Braking
2003 Cobra 17x9s Chrome
Nitto 555DR 275/40/17 Drag Radials on back
Nitto 555 Extreme 275/40/17 on front
2003 10th Anniversary Cobra Calipers Red on front
13" Proslot slotted rotors on front
New Stock drums and pads on back
93 Cobra Master Cylinder
MM stainless steel brake lines
[/align]Weld Prostars 15x10 w/ 6.5" BS
[/align]Mickey Thompson ET Drags 26x15x10
Weld Prostars 15x3.5" with Moroso DS-2s on front
[/align]
Interior
Florida 5.0 Custom 6 gauge cluster w/ autometer gauges
Autometer Pro Comp Vac/Boost gauge
Autometer Pro Comp Pyrometer
All Black interior minus the rear seat
Corbeau LG1 Microsuede seats
ACC Black Carpet
New Black Door Panels w/ SVT logo
MOMO Jet Steering Wheel
MOMO F1 Shifter
Sorry no new pics lately been too busy
at the dyno
final numbers for the day when we saw 11.75#s of boost were 599.6RWHP and 610.8RWTQ *********PUMP GAS 91 OCTANE*******, if you do the math 11.75/14.7 +1 * 350=629RWHP we could have made the 629 by leaning it out the other 1/2pt but we kept it simple and very safe, here are the dyno sheets, not sure what the hell was up with the MPH, the dynapac dynos are a lil goofy when recording those numbers, oh well, should run some nice numbers on the track
shouldnt have any trouble pushing past the 800RWHP mark, we will find out later this year
link to build here on MF
http://www.mustangforums.com/m_39157..._1/key_/tm.htm
__________________
Dart IE 347 Stage 3 T76 @ 11.75#s 600RWHP 611RWTQ lightly tuned PUMP GAS
Drag Radials 12.2 @ 123mph, slicks 11.2 @ 122 rear end gettin loose in 3rd and 4th
ruger311 is offline   Reply With Quote
Old 05-22-2008, 12:06 AM   #32
Jaked4e
Send a message via AIM to Jaked4e
stock 302
vortech super charger
bbk shorty headers
Flowmaster o/r X pipe
short shifter
cobra clutch
ET 1/4 mile soon
__________________
Vortech Super Charger, BBK headers, custom O/R X Pipe, MSD Ignition, A/C Delete,
Jaked4e is offline   Reply With Quote
Old 05-22-2008, 12:33 AM   #33
1SLO85
1SLO85's Avatar
Quote:
ORIGINAL: Jaked4e
stock 302
bbk shorty headers
short shifter
cobra clutch
ET 1/4 mile soon
__________________
1SLO85 is offline   Reply With Quote
Old 06-08-2008, 12:22 PM   #34
93 LX FiveO
1992 Ford Mustang
93 LX FiveO's Avatar
Vehicle: 92 LX 5.0
Send a message via AIM to 93 LX FiveO
1992 mustang lx 5.0
calypso green
5 speed w/ 2.73's
150k miles
current mods:
aluminum radiator
powerslot rotors / hawk pads
65mm throttle body
75mm mass air meter
bbk adjustable fuel regulator
bbk cold air induction
bbk shorty headers
bbk o/r h-pipe
loud flowmasters
mgw short throw
double hook quadrant
firewall adjuster
electric fan
no emissions
no a/c
kyb agx shocks / struts
ford c-lowering springs
ford HD lower control arms
bbk caster / camber plates
255/50/16 coopers in the rear
black interior
loud stereo
best 1/4 mile: 15.0 @ 93 (when it was stock)
__________________
new project website
93 LX FiveO is offline   Reply With Quote
Old 06-08-2008, 05:35 PM   #35
9 Sec 93 LX
R302 block bored to 4.080" w/3.500" billet stroker crank.364 cu in (roughly)
5.400" H beam rods, Venolia custom domed pistons w/Chevy tool steel wrist pins, 13.8:1 actual compression.
Canfield 20-450 heads fully ported w/ 2.08 int and 1.625 exh SS valves.Angle milled and O ringed, .043" SCE copper head gaskets.
Triple valve springs,7/16" studs double bar stud girdles,roller rockersand titanium retainers.
Victor Jr. fully ported and matched to heads,w/ 2" open spacer, nitrous fogger nozzles and 1/2" nitrous plate.
750 race Demon,full MSD ign. w/7AL box (9000 rpm high chip), adj. timing computer,Pro power coil,billet dist.ceramic coated plug wires and NGK 9 plugs
Comp cams solid roller w/ .729 int .744 exh lift, 278 int 288 exh duration lashed @.026 int and .028 exh (cold).
Innovators West billet aluminum damper,Mezeire elec. water pump, small dia. crank pulley,Canton oil pan, Milodon oil pump and H/D driveshaft.
Mr Gasket crankcase evacuation system, Mobil One 15W50 synthetic oil,Fram HP filter.
2" primary headers feed into 3.5" collectors into a custom 3" dual exh w/ single chamber Flowmasters and turndowns. BG400 and BG280 fuel pumps feed AN8 lines to three pressure regulators (one for carb, one for each nitrous stage)
647 HP @ 7400 rpm and 497 lbs ft @ 5500 rpm NA on the engine dyno.
2 stage NOS nitrous system could easily double that number.( If she would only stay on the track)
C4 tranny w/ revpattern valvebody and brake.9" nitrous convertor w/ anti ballooning plates,
164 tooth JW "The Wheel" flexplate w/ 8 bolt hub,flexplate and tranny shields.
8.8" rearw/ Strange Eng 33 spline axles,spool, 9" Ford axle bearings and 11/16" drive studs(4 lug).
Aerospace brakes F/R and master cylinder, converted to non power (manual) and modified brake pedal leverage ratio.
Stock (Type) rear suspension has Mega Bite Sr uppers and lowers,Spherical bearings in rearend housing,Dual anti sway bar and air bags, CE 3 way adj shocks,and Eibach springs.
Frontend features tubular K member and control arms,Steeda C/C plates,Eibach springs, Lakewood 90/10 struts
Weld Drag Lite wheels are 15x3.5 front and 15x8 rear, MT ET fronts are 26 x 4.5 x15, Rears are MT ET Streets 12.5 x 28 x 15.
Best times (So Far) are 10.741 @130.18 NA with a 4.30 gear.
9.86@138.98 with a single stage 125 shot and the 4.30 gear.
9.12@152.44 with a single stage 300 shot and a 3.73 gear.
Haven't tried the second stage yet.(that whole staying in your own lane thing)
[IMG]local://upfiles/95778/36415FB4F60143B4A31383185D63FD5B.jpg[/IMG]
__________________
Use your head,
Race safe.(safely)?
Tommy
9 Sec 93 LX is offline   Reply With Quote
Old 06-09-2008, 12:07 PM   #36
HACKGT350
HACKGT350's Avatar
Send a message via AIM to HACKGT350
84 1/2 20th anniversary GT350
192k original miles
new astro performance T5 good for 450ft lbs tq
centerforce II clutch
holley 600 vacuum secondaries, tweaked out as much as possible
steeda clutch quadrant kit
holley red fuel pump
94 sable 3.8 fan only 25 bucks
hurst compitition plus short throw w/white ball knob
a/c p/s and smog delete.
all unnessasary vacuum lines removed
ford racing stamped steal crome valve covers and air cleaner
dynoed 173 rwhp and 261 rwtq
best 1/4 15.01 @ 93mph 2.7 60'
oh and its a daily driver
yes i drove right out of all the snow with out getting stuck with summer tires on
__________________
Quote:
ORIGINAL: FiveLiterRiceEater
i saw this whore do a sweet trick with about 7 ping pong balls...
Quote:
Originally Posted by simpsonfan13 View Post
you haven't been nominated yet maple sucker..
84 1/2 20th anniversary GT350 5.0 5 speed
99 cherokee xj sport
HACKGT350 is offline   Reply With Quote
Old 07-16-2008, 11:24 PM   #37
jwyche
My Little Red Fox.
• 347 With ARP Fasteners
• Motorsport X303 Cam
• SFI Balancer
• Underdrive Pulleys
• Canton Drag Race Pan & Oil System
• Canton Block Girdle
• Crane 1.7 Roller Rockers
• Motorsport GT-40 Intake
• Edelbrock/BBK 70 mm Throttle Body
• Mac Cold Air Intake
• C&L 73 mm Mass Air
• Motorsport 30 lb. Injectors
• Kirban Adjustable Fuel Pressure Regulator
• NOS 150 HP Dry Nitrous System
• AFM Nitrous Controls
• Edelbrock Performer Aluminum Heads
• Taylor 409 10.4 mm Race Wires
• MSD 6AL Ignition & Blaster Coil
• Diablo 3-Way Custom Chip
• Mac Ceramic Coated Long-Tube Headers
• Mac Off-Road H-Pipe
• Flowmaster Mufflers
• Mac Chrome Exhaust
• Spec Stage 3 Plus Clutch
• Tremec 3550 Transmission
• Hurst Shifter
• Hurst Line Loc
• Motorsport Aluminum Driveshaft
• 4.56:1 Gear
• Auburn Pro Differential
• Moser 31 Spline Axles
• Torque Boxes and Seams Welded
• Trunk Mounted Battery
• 255 LPH Walbro Fuel Pump
• Auto Meter Gauges
• Tilt Steering From 1989
• Pioneer Satellite AM/FM/CD/XM
• Cobra 13" Drilled Front Brakes
• 2002 PBR Drilled Rear Brakes
• 17X8 Cobra R Wheels Front
• 17X10 Cobra R Wheels Rear
• Pirelli P7000 Radials 255/45 Front 275/40 M/T Drag Radials Rear
• Granatelli Tubular K-Member
• Ground Pounder Tubular A-Arms
• Ground Pounder Coil-Overs Front and Rear
• KYB-Adjustables
__________________
1992 Mustang GT. Check it out at http://homepage.mac.com/jwyche/Menu2.html
[IMG]http://s273.photobucket.com/albums/jj240/jwyche_photos/?action=view&current=Front341992Mustang.jpg[IMG]
2002 GT
jwyche is offline   Reply With Quote
Old 07-17-2008, 03:49 PM   #38
Shelty
1991 Ford Mustang
Shelty's Avatar
Vehicle: '91 5.0 LX 'vert
Send a message via AIM to Shelty
1991 LX convertible
128K miles
Engine
Kenne Bell Ram Air Kit
Aluminum Underdrive pullies-unknown brand
Exhaust
BBK equal length shorties
Mac Prochamber O/R x-pipe
Mac Catback
Drivetrain
Spec Stage II clutch
Steeda Tri-Ax with hurst knob
Aluminum driveshaft
stock gear ratio[&:] previous owner did it...
brakes
Power Slot Rotors
brand new ford OEM bearings
Ignition
Taylor 8mm Wires
"dress up"
5.0 floormats
2.5 inch cowl hood
shaved decklid
new white top
new white uphoulstry
UPR billet door handle bezels
clear corner stock headlights
old photos, just pretend the side exhaust is gone and chrome tailpipes are there
__________________
'91 5.0 5-speed
full O/R exhaust, Ram Air Intake,pullies, full length SF connectors, CF DF clutch, tri-ax, aluminum drive shaft, slotted rotors, strange 10 ways, exterior mods/ some interior billet bling
soon...more suspension work i.e. control arms, springs, ball joints, bushings etc in due time (Imma broke college lad)
Shelty is offline   Reply With Quote
Old 07-17-2008, 04:53 PM   #39
jwyche
Try again. I'm doing something wrong when I upload. It accepts as successfully uploaded but then I don't see them.
My Little Red Fox.
• SFI Balancer
• Hurst Shifter
• Hurst Line Loc
• 4.56:1 Gear
• Auto Meter Gauges
• KYB-Adjustables
__________________
2002 GT
Old 07-18-2008, 01:00 AM   #40
IN2FORD
IN2FORD's Avatar
Well here is mine and mods are:
Engine:
306
GT40 ported iron heads
B303
Cobra 1.7 roller rockers
Cobra intake
24 pound injectors
73mm C&L
BBK Air intake
Shorties
65mm TB
No cat H pipe
Flowmaster American Thunder series catback
Suspension:
Cobra front brakes
Turbo Coupe rear disc brakes
3.55 gear limited slip
H&R Sport springs
BBK upper and lower control arms
Subframe connectors welded
17x9 Cobra wheels 255/40 front and 275/40 rear
Barry
__________________
IN2FORD
Barry
IN2FORD is offline   Reply With Quote
150, 2556015, 347, atrim, density, drag, draglite, mustang, nos, speed, supercharger, time, tips, tuning, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
