Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-12-2008, 05:54 PM   #41
86HOGT
1986 Ford Mustang
86HOGT's Avatar
Vehicle: 1986, Ford, Mustang GT
Default Can I finally play?
Engine
347 SCAT Stroker
AFR 185 Heads w/ Upgraded Springs
Comp Cams XE274HR
Fully Ported GT 40 Lower
Comp Cams Polymer Upper
70mm TB
76mm C&L Tru Flo Tube
Canton 7QT Oil Pan
Canton Main Stud Girdle
Canton Windage Tray
Crane 1.6 Full roller Rockers
Rocker Stud Girdle
Melling High Volume Pump
30lb/hr Injectors
Mass Air Conv.
A9L
BBK FPR
Brother's Perf. 190L/hr pump
BBK Ceramic Coated LTs
BBK O/R X Pipe
Flows
Drivetrain
Centerforce Dual Friction Clutch
Stock rebuilt T-5
3.73
Suspension
Five Lug Conversion
2000 Spindles
11" Rotors w/ Dual PBR Calipers
KYB AGX Struts
Rear SN95 Disc Brakes
Lakewood drag shocks
Ford Racing Lowering Springs
Welded Subframe Connectors
HPM Mega Bite Jr. LCAs
Wheels/Tires
AFS 17x8 and 17x9 03 Mac Black Cobras w/ machined face
Kuhmo Ecsta 711 245/45/17
Cooper Zeon 2SX 275/40/17
Exterior
87-93 Rear Quarter Glass
Custom Made Cowl Hood
Spoilerless Fiberglass Hatchback
__________________
Car Domain
86HOGT is offline   Reply With Quote
Old 08-12-2008, 06:03 PM   #42
EliteTuners
EliteTuners's Avatar
Vehicle: 89 Ford Mustang
Send a message via AIM to EliteTuners
Default My TT 347
Fully forged 347 Stroker
Mexican block
Edelbrock Aluminum Heads
TFS2 Cam/Upper/Lower
Twin 58AR Turbos
Few other "minor" mods.
150 shot if i get traction.
I'll list the rest later.
Pics:http://mustangforums.com/forum/members-rides-and-car-show-section/473265-im-back-and-a-new-ride.html#post5344241
__________________
~ http://v8powered.net
Looking to buy an 87-93 running 5.0 near stock
EliteTuners is offline   Reply With Quote
Old 08-27-2008, 05:11 PM   #43
5.0stang123
Vehicle: 1990 mustang lx 5.0
Nice cars guys, Ill try and get mine up
__________________
90 mustang 5.0 lx 25th aniv gray(black interior)
Powerslot rotors/hawk pads
Eibach pro kit springs, tokico hp struts/shocks, MM cc plates
Dynomax exhaust, no cats, 3.73 gears
J&M subframes, steeda tri ax
5.0stang123 is offline   Reply With Quote
Old 09-20-2008, 10:09 PM   #44
PhantomUSA1
Default Remember Bad Boys of the 5.0
It is not a mustang but it is a bad boy of the 5.0
1990 Lincoln Mark VII LSC Special Edition
4:10 gears locker rear end
2.5 Exh
T-5 swap
96 Explorer 5.0 GT 40 3 bar Eng
93 Cobra cam & 1.7
65.mm T.B. W/70.mm Egr plate
Mass air with A9P Conp.
24LB Inj
under drive pullies
Elc. Fans
ZEX 75-150 HP Nos.
No clue on HP or 1/4 times sorry just got it running and need to tune it
CRAP I Don't know how to post photos here
__________________
__________________
If you don't have a good sense of HUMOR DON"T post next to me
PhantomUSA1 is offline   Reply With Quote
Old 10-31-2008, 04:32 PM   #45
hi_tek_rednek
1989 Ford Mustang
hi_tek_rednek's Avatar
Vehicle: 1989 gt hatch
heres mine. work in progress.
engine
347c.i. stroker
crane cam
world windsor sr. heads
polished parker funnel web intake
billet hei dizzy
comp cam roller rockers
hand fabbed sheet metal valve covers
holley 750
electric water pump
(coming soon)
shorty headers w/ drop outs right behind the front wheels
electric fan
C4 tranny
suspension
full comp engineering race sus.
8.8 w/ 4.10's and locker
26" M/T full slicks
weight reduction= everything gone. interior completely stripped.
10 pt cage
race seat
5 pt harness
gauges
tach
oil press
water temp
3 gal fuel cell
holley blue electric fuel pump
est H.P= 450 at the crank
vehicle weight about 2100# with driver
will..
__________________
'89 5.0
347 and some other stuff.
hi_tek_rednek is offline   Reply With Quote
Old 11-03-2008, 07:19 PM   #46
uedlose
1989 Ford Mustang
uedlose's Avatar
Vehicle: 89 mustang
update on my new set up 2nd time down the track 10.37 1/4 and 6.66 in the 1/8 109 mph and lost a head gasket and slowed to 125 MPH in the 1/4. 306 R-block GT80R turbo, performer rpm intake, ported TFS TW heads, Cam Motion turbo cam. C-4 3500 stall 331 rear gears. good fuel system in a street car.
__________________
New low boost times 11 psi 10.91 @ 128 MPH 1.76 60ft 6.98 1/8 mile. still only a 306 CID yes its been a lot faster.
uedlose is offline   Reply With Quote
Old 11-06-2008, 12:52 AM   #47
RVC
Default Not a 5.0 but we are all car guys.....
I do own a 5.0 by the way.....but I don't consider it worthy to be in the bad boy section!
1964 Chevy II Post car
355 SBC, old school camel humps 2.06/1.90 ported and polished flow tested
6-71 triangle plate blower
Lots of "tricks" in this engine
JE custom made blower pistons
Chet Herbert custom grind blower cam
Eagle ESP H-beam rods
Callies 4340 forged crank
ARP fasteners
Comp Engineering backhalf
Tubbed, 10 point cage
31X16.5 MT E/T Streets, skinnies out front
Rattle can flat black
Plus lots, lots more!
RVC is offline   Reply With Quote
Old 12-10-2008, 02:31 PM   #48
Sneakerhead4345
Vehicle: 1990 Mustang GT Hatchback
Dont Know Specific Specs But This Is My Fathers Stang.
1990 Cobra GT
302 bored over to a 305
JP Pistons
TrickFlow Heads
C-4 Tranny
Novi 2K w/ 20 psi @ 6700
80 wet shot of NOS
4.10 gears
Full Racing Rear-end
Mickey Thompson ET street 17" tires
Weld-Racing Rims
Car is not tuned but has run 6.80 at the 1/8 w/ a 1.59 60'
Driven to the track and back
car will see a low 10 when its all said and done
Pics coming soon
Sneakerhead4345 is offline   Reply With Quote
Old 12-11-2008, 01:42 PM   #49
PRO50SC
The Rogue Mod
1992 Ford Mustang
PRO50SC's Avatar
Vehicle: 92 Notch Procharged!
Send a message via AIM to PRO50SC
Quote:
1990 Cobra GT
JP Pistons
TrickFlow Heads
C-4 Tranny
80 wet shot of NOS
4.10 gears
Weld-Racing Rims
Pics coming soon
Is that a new model? Never heard of one of those
__________________
92 LX NOTCH PROCHARGED
DRIVE IT LIKE YOU STOLE IT!!!
ROTM 08/06
11.761 run from 4/4/09
See my Movie
Wheels up!!
PRO50SC is offline   Reply With Quote
Old 12-11-2008, 10:32 PM   #50
Explosive
1979 Ford Mustang
Explosive's Avatar
Vehicle: 1979 Ford Mustang Cobra
Not sure if I ever posted in here so I will now,
Link to build, http://www.mustangforums.com/forum/5...ng-videos.html
Pics,
__________________
Exhaust Video: http://www.youtube.com/watch?v=HsPGeW0C4UA
Exhaust/Walk around:http://www.youtube.com/watch?v=Nyz2oJVZYaI
FlyBy Video:http://www.youtube.com/watch?v=g9swmwqDJIo
Inside Car Video:http://www.youtube.com/watch?v=xUarrgjxltE
Voted Best Avatar Of 2008
Explosive is offline   Reply With Quote
150, 2556015, 347, atrim, density, drag, draglite, mustang, nos, speed, supercharger, time, tips, tuning, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
