Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-16-2008, 04:40 AM   #51
5.0 EFI MAN
5.0 EFI MAN's Avatar
Vehicle: 93' ford mustang LX
Default 1993 LX v8 swap!!
Swapped out 2.3l for 5.0.
High compression head gaskets
Chromeoly race rings
Bigger valves, radius grind
BBK underdrive
Alluminum radiator
Crane cam
Trick Flow lifters, timing chain
MSD wires
Pro billet distributor
Eibach drop kit 2"
MTX stereo
__________________
If it aint sideways its just doggy!!!
5.0 EFI MAN is offline   Reply With Quote
Old 12-20-2008, 03:20 PM   #52
BlessedHellride
1988 Ford Mustang
Vehicle: 1988 Ford Mustang
4cyl conversion car. 88 Notchback with a long list of goodies. 347cid, C4 w/brake. Best E.T.- 11.92 @ 113mph, 1.67 60'
__________________
88 Notch 347, C4 w/brake, 3K stall, Alum. drive shaft, 3.90 gear 8.8"
Best N/A E.T.- 11.92 @ 113mph. Best 60' - 1.67
www.fquick.com/BlessedHellride
BlessedHellride is offline   Reply With Quote
Old 12-21-2008, 08:05 AM   #53
roostracing
roostracing's Avatar
Vehicle: 1991 Ford Mustang Coupe
never even looked in this thread before but here is mine so far:
1991 Mustang LX Coupe
bbk long tube headers
bbk off road h pipe
magnapacks w/dumps
c&l true inlet pipe
MSD wires
MSD cap and rotor
MSD blaster coil
March underdrives
k&n panel filter
king cobra clutch
promotion quadrant/cable system
mgw shifter
strange 10 way struts
31 spline moser axles
detroit locker
3.73 ford racing gears
Trick flow diff cover
3 inch studs all around
15x10 pro stars
26x10x15 et drag
Best ET of 13.26 @ 100mph
New times coming soon in early Jan!
__________________
1991 Ford Mustang LX coupe, 5.0, 5spd (white)
13.12 @ 101.3 mph n/a
1.64 60 ft
(stock uncracked motor on slicks)
2009 Harley Davidson Crossbones (Denim Black)
"When speed gets in the blood, one must drive to live."
roostracing is offline   Reply With Quote
Old 12-27-2008, 11:53 PM   #54
Sparky73
1980 Ford Mustang
Vehicle: 1980 Ford Mustang Cobra
Send a message via AIM to Sparky73
1980 Mustang Cobra. No times on it yet. Will be this coming Spring.
Engine:
302 .60 over
351 Windsor heads
Edelbrock performer 289 intake
ARP Fasteners throughout engine
Double roller timing chain
Flat top pistons
Mild cam
High volume oil pump
Transmission:
C4 automatic 3 speed
B&M Strip shift kit
Ignition:
Jegs timing pointer
Trunk mount battery kit
Computer controlled distributor
MSD Blaster coil
85 amp alternator
Fuel:
Holley 600cfm 4 barrel carb
Jegs 12 gallon fuel cell
Aluminum 3/8 fuel line ran from tank to engine bay
Cooling:
High flow water pump
Oversized radiator
190 thermostat
Exhaust:
1-5/8 Shorty headers
2-1/2 headers back exhaust
2 40 series Flowmasters with dumps
Suspension:
Ford 9" rear end
Rear springs w/ air bags
Full length sub-frame connectors
Interior:
1991 GT power seats
Exterior:
Custom blue pearl and silver paint
Rear window louvers
Side skirts/rear valance have "Cobra GT" cut outs that light up
__________________
1998 Chevrolet K1500 Z71
1970 Opel GT
Sparky73 is offline   Reply With Quote
Old 12-28-2008, 12:17 AM   #55
luckythirteen13
luckythirteen13's Avatar
Quote:
Originally Posted by PRO50SC View Post
Is that a new model? Never heard of one of those
i think thats what they call GTs built in canada
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 12-28-2008, 11:55 PM   #56
fs308
1995 Ford Mustang
My Garage
fs308's Avatar
Vehicle: 87 piece of sh!t
REMEMBER ONLY 2 PICTURES!!!!
__________________
Project:POS
fs308 is offline   Reply With Quote
Old 01-04-2009, 02:02 PM   #57
Green Machine 123
Vehicle: 1988 mustang lx coupe
Default Black Sunshine
1988 Mustang Coupe
Mac cold air intake with mass air conversion
Full Mac exhaust from the headers to the tail pipes
3.73 gear
aluminum drive shaft
hurst shifter
3 core rad
drag eibach springs with 70/30 edlebrock shocks
drive shaft loop
battary relocation kit
cobra upper and lower
Green Machine 123 is offline   Reply With Quote
Old 01-13-2009, 09:19 PM   #58
v8440
Vehicle: 1994 Cobra
I haven't mentioned this car because it doesn't have a motor or transmission right now, but I have a '91 notchback that has been fairly quick. It's best pass was a 9.76 at 137.something. It went a 6.22 at about 111 in the 1/8th on that pass. Here's what it had/has:
393 stroker, victor jr heads stage 2 ported by Bennett Racing, solid flat tappet cam with lift in the low 600's on the intake, around .580 on the exhaust. It was some kind of circle track cam, believe it or not. It was based on an early 351w block, with a scat crank, STOCK 351 rods (!), and a 302 piston of some sort. It was rounded out with a victor jr intake, 1000 hp carb, bbk long tube headers, and an edelbrock plate kit jetted for a 200 shot.
Chassis-wise, it has an 8 pt cage, welded in subframe connectors, 8.8 with a spool, aftermarket axles (I think 31 spline, not sure), wolf racecraft rear upper/lowers, granatelli front crossmember and strut setup, c clip eliminator kit, 4.10's in the 8.8.
Leaving on a 200 shot netted mid 1.3 short times, foot braking it. Oh, the transmission was a c4 with a shift kit and good clutches. No transbrake or manual valvebody. The trans would surprisingly last pretty well, at least 30 or 40 hard passes, before it would start the 3rd gear flare. The last time I had it benched the stock planetaries were getting kinda sticky, like they wanted to bind up. More stock used planetaries were put in it.
This engine would run fine on 93 octane on the motor. Some race gas mixed in was enough for the nitrous. I drove this car to and from the track, as well as around town sometimes. The power windows and locks still work in it, which is good since the rollcage bars would block the handles if it had manual windows.
The reason I'm vague on some technical details about the engine and rearend is because I didn't build the car or engine-I bought it already set up. The only stuff I did was put the suspension stuff on, have the 4.10's put in (in place of 3.55's) and get the heads ported.
The 393 started gradually losing oil pressure, so I sold it back to the guy I got the car from, minus the heads. Those I ebayed. I wish I had kept them-they might have been a decent choice for the cobra I have now. Now this is the part that's gonna piss some folks off-the reason I sold the engine instead of freshening it up is that I'm basically a chrysler guy at heart, so I'm gonna be putting a big block chrysler in the car. I have a ton of parts for them, and I know more about them than I do any other engine. The cobra of course will be staying with ford smallblock motivation.
v8440 is offline   Reply With Quote
Old 01-24-2009, 03:15 PM   #59
sales@genesisautoparts.com
Former Sponsor
sales@genesisautoparts.com's Avatar
Vehicle: 1967, Ford, GT500
nice car
sales@genesisautoparts.com is offline   Reply With Quote
Old 03-03-2009, 05:40 PM   #60
pur pony
1989 LX Coupe- 563RWHP / 610RWTQ
R302 Block
Trick Flow heads
Trick Flow Heat intake
75mm Accufab throttle body
75mm Pro-M mass air
Custom grind CompsCam
Incon 800 twin turbo kit w/ intercooler
Canton Race Oil Pan
SCT Chip Tuned by Chris @ EFILogics
Aeromotive complete fuel system
55lb Seamens injectors
Custom 2.5” h-pipe
MagnaFlow Exhaust
Crane ign
Fluidyne Aluminum radiator
T-56 Viper spec 6-speed
D&D short throw shifter
Mcloed Twin disc clutch
Steeda cable and quadrent
Griggs tubular K-memebr
Griggs tubular front a-arm
Griggs tubular rear lower control arms
Maximum motorsports Torque arm
Griggs panhard bar
Koni yellow adjustable struts and shocks
Griggs front and rear coil-overs
Kenny Brown full length subframes
Kenny Brown Jacking rails
Kenny Brown Matrix kit
Maximum Motorsports Caster/Camber plates
Maximum Motorsports Strut tower brace
Currie Enterprises Custom 8.8 rear w/ 9” end caps
31 Spline axles
Posi
Baer Brakes (13” fronts, 12.5” rears – cross drilled)
Aluminum rearend girdle
ROH 17x8.5 and 17x9.5 Wheels
Nitto 245x40x17s
Nitto 275x40x17s Drag Radials
Kenwood CD player
Kenny Brown super street cage
Corbeau GTS II Black leather seats
Autometer gauges
Tinted windows
Hardwood 2 ½ cowl hood
Custom BMW E46 HID Projector Headlights
__________________
1989 Notchback- Twin Turbo
2004 F-150 SuperCrew Lariat
2002 Polaris Sportsman 700
2003 Yamaha R1
2004 SkiDoo Renegade 800
pur pony is offline   Reply With Quote
150, 2556015, 347, atrim, density, drag, draglite, mustang, nos, speed, supercharger, time, tips, tuning, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
