ticking not from engine, or any noticeable place
Old 02-05-2008, 10:52 PM
302army187
302army187's Avatar
Default ticking not from engine, or any noticeable place
eversence i got the car, when im driving i hear a ticking noise.
the easyest way i can discribe it, is that it sounds like a bike with a card in the tires.
i think its coming from one of the wheels, and ive looked at them with the car on the ground but cant see anything.
also dont have the tools to take things off right now, as i just got the car.
its not very loud, but with the windows down from about 40mph-0 its pretty bad but above that its fine
just wanted to know if anyone else has experenced this, and what it is.
thanks
302army187 is offline
Old 02-05-2008, 10:53 PM
Maxwelhse
Maxwelhse's Avatar
Default RE: ticking not from engine, or any noticeable place
Does it change with brake pedal pressure? I've heard pads with broken hardware make a similiar noise.
Maxwelhse is offline
Old 02-05-2008, 11:02 PM
302army187
302army187's Avatar
huh, maybe, i only really notice it when im at lower speeds, im about to leave work in 2hrs, so ill check it then.
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
could be anything from a exhaust header gasket to brake hardware issues to a million other things....if you had a video of the noise it might help narrow down the possibilities
mjr46 is offline
Old 02-05-2008, 11:04 PM
302army187
302army187's Avatar
hahaha very very true.
im just new to this car and was thinking this happens alot.
ill do a few lil things on the way home, and update
Old 02-05-2008, 11:07 PM
mjr46
mjr46's Avatar
cool..keep us posted
mjr46 is offline
natbel08
natbel08's Avatar
the mustang stock h pipes are known for cracking right above the second catalytic converter
you probably wont be able to tell unless you take the h pipe off
i dont really think you havethe stock h pipe, but just in case
natbel08 is offline
Old 02-05-2008, 11:10 PM
302army187
302army187's Avatar
i do have the stock h pipe (looks like it atleast, rusted to hell and back)
i just have a catback right now.....
the noise gets faster when speeding up, and slower when slowing down (duh) but just sounds like the wheels.............
idk, i need to get some jack stands so i can look under the beast
Old 02-05-2008, 11:14 PM
Maxwelhse
Maxwelhse's Avatar
You sure there isn't a 1981 Oldsmobile with wire hubcaps following you around everywhere?
click-click-click-click...
Old 02-06-2008, 07:20 AM
raven_ghostwolf
raven_ghostwolf's Avatar
could be u-join or speedo cable as 2 other items to check for.
raven_ghostwolf is offline
Quick Reply: ticking not from engine, or any noticeable place
