my 95 saleen clone for the drag strip and street
Old 02-21-2008, 01:21 PM
wadman1
wadman1's Avatar
Default my 95 saleen clone for the drag strip and street
this is my 95 saleen clone. it will be ready shortly for the drag strip, street racing or cruising.
this car is far from done. but i thought you might enjoy taking a look. let me know what i am missing or what you think the car needs.
x
x
x
x
1. My 1995 Mustang
2. _______________
3. ENGINE
4. 347 stroker is going in
5. __________________
6. IGNITION
7. Car Also Has Painless Wiring For 89 Electronics
8. Has Anderson Switch Panel
9. Wired For Electric Water Pump
10. Electric Fan
11. Line Lock
12. Battery Relocated To Trunk 1 Gauge Wire
13. Flaming River Big Battery Switch
14. _________________
15. EXHAUST
16. Bassini off road x pipe
17. Flowmasters
18. _________________
19. DRIVETRAIN
20. 8.8 Rear With 3.73 Gears
21. 33 Spline Moser Avxles
22. 33 Spline Strange Spool
23. Ta Girdle And
24. Stud Kit
25. New Bearings
26. Seals
27. Tubes Welded
28. Rear Has 9" Ends
29. Safety loop
30. ____________________
31. TRANSMISSION
32. not in yet
33. Tremec TKO
34. Tremec bell housing
35. McCloud clutch
36. ____________________
37. SUSPENSION
38. Front Suspension Anthony Jones K-Member
39. A-Arms
40. Coil Overs Tokico Adj. Drag Struts
41. Upr Caster Camber Plates
42. Upr Coil Overs front
43. Flaming River Manual Rack Kit
44. Lakewood 50/50 Shocks
45. With Coil Over Kit rear
46. Torque Boxes Are All Reinforced With Wild Rides Battle Box Kit
47. Rear Has Double Adjustable Upper Control Arms And
48. Mega Byte Jr Lower Control Arms
49. Steering Shaft
50. ___________________
51. EXTERIOR
52. New Blue Paint
53. Real Saleen Ground Effects and Wing
54. Cobra R Hood (Cervini)
55. New Head Lights
56. _______________________
57. WHEELS
58. Not yet
59. ____________________
60. BRAKES
61. Front and Rear Cobra Disc Brakes
62. Braided Brake Lines
63. Crossdrilled Slotted Rotors
64. Line lock
65. ____________________
66. INTERIOR
67. B&M Hammer Shifter (coming out)
68. New Black Carpet
69. No Factory Gauges All Auto meter
70. Fuel Level
71. Speedo
72. Tack
73. Shift Light
74. Low Oil Warning
75. Engine Temp
76. Trans Temp
77. Oil Temp
78. Boost/Fuel Pressure
79. Voltage
80. Oil Pressure
81. Braided Line For Oil Pressure Gauge
82. Has New Ignition Switch
83. New Carpet In Trunk
84. Door Locks
85. New Power Trunk Release
86. New Trunk Lock
87. Sill Plates
88. ______________________
89. AUDIO
90. New Alpine Radio
91. Polk Speakers
92. _________________________
93. FUEL
94. Aluminum 15 Gallon Fuel Cell
95. Fuel Level Sending Unit
96. Roll Over Vent
97. All Braided Fuel Lines Are In Car #10 Feed #8 Return Fittings
98. All Attached Just Need Pump and Regulator
99. _____________________
100. SECURITY
101. Not yet
102. ________________________
103. ENGINE BAY DRESS UP
104. Painted and cleared
105. ________________________
106. EXTRAS
107. Roush Tool Kit In Trunk
108. Sub Frames Connecters Welded In
109. Wired For Trans Brake
110. Pia Headlight Bulbs
111. All New Bulbs /Fuses/ Heater Core/ Headlight Switch New Parking Brake Cables
112. Under Car Is Also Pained Same Color And Clear Coated
wadman1 is offline
Old 02-21-2008, 02:23 PM
mantis118
mantis118's Avatar
Default RE: my 95 saleen clone for the drag strip and street
427 stroker. lol. Nice car man. Good luck with it!
mantis118 is offline
Old 02-21-2008, 02:50 PM
stang8689
stang8689's Avatar
She's gonna be sweet when its done
stang8689 is offline
Old 02-21-2008, 06:25 PM
TTGreenSN95
TTGreenSN95's Avatar
Thats a longgggggggggggg list of mods!!Did you put the salean kit on it yourself?
TTGreenSN95 is offline
Old 02-22-2008, 09:31 AM
wadman1
wadman1's Avatar
i did not put the kit on the car. and the list will be much longer soon.
wadman1 is offline
Old 02-22-2008, 09:34 AM
wadman1
wadman1's Avatar
ORIGINAL: mantis118
i got a 347 already built. it has 450 hp and that is with out my 150 shot.
i wanted to suppercharge it but i have 11 to 1 compreson.
will it be safe to run real low bost?
wadman1 is offline
Old 01-23-2010, 08:32 PM
wadman1
wadman1's Avatar
to the top. 2 years i have let this car sit, but i plane on driving it in a month. i will post some updates soon. i have a few ?s too.
wadman1 is offline
Old 01-23-2010, 09:06 PM
w8less
w8less's Avatar
shoot whats the questions
w8less is offline
Old 01-23-2010, 09:50 PM
wadman1
wadman1's Avatar
this car is an auto 95 roller. i have a Tremec tko and 1993 347 going in it.
what will i need and need to do.
again it is a tremec tko from a 93 in my auto 1995 mustang with the a 1993 347 motor. some say all i need is a driveshaft extension?
Has any one here done this?
also will 1993 shorty headers and xpipe bolt on my 95 with a bit of love or is that a no go? will the Anthony Jones K-Member and tko help with room for the 93 exhaust? Thanks wadman
wadman1 is offline
Old 01-23-2010, 11:49 PM
AdderMk2
Banned
AdderMk2's Avatar
this is why you dont ask the same question in two threads....
go read your other thread
AdderMk2 is offline
Quick Reply: my 95 saleen clone for the drag strip and street
