who would win?
who would win?
So a friend of mine, is doing some work 89 foxbody gt vert 5spd. He is getting
Cobra intake manifold
E303 cam
weiand water pump(does this actualy help?)
BBK longtubes, BBK o/r Hpipe, American Thunder flowmasters
Scorpion Roller Rockers
Richmond 3.73 gears
BBK 75mm TB
BBK CAI
80MM MAF
Injectors
he also may have a built rear and drag radials
vs.
2002 GT coupe 5spd
with (at the time of race will be )
Goodyear Slicks
built 31spline rear
4.10s
Max Motorsports FLSFC's
Drag rate coilovers from MMR
Lakewood 90/10 fronts
Comp Eng. rear shocks
TKO 600
Tri-Ax shifter
Spec 3+ clutch
Mac Pro Dumps
o/r xpipe
BBK CAI
BBK 70mm TB
No front swaybar
This will be at MIR so its at least a dig race.
this is posted in the 4.6 and 5.0L general discussion
E303 cam
Richmond 3.73 gears
BBK 75mm TB
BBK CAI
80MM MAF
Injectors
vs.
2002 GT coupe 5spd
Goodyear Slicks
built 31spline rear
4.10s
TKO 600
Tri-Ax shifter
Spec 3+ clutch
Mac Pro Dumps
o/r xpipe
BBK CAI
BBK 70mm TB
No front swaybar
RE: who would win?
02 will win for reasons listed above, plus traction off the line, If you can drive, then you can definitely hook your buddys Fox. Also, verts make bad daily drivers turned drag cars. They weigh a lot.
RE: who would win?
Him and his little brother swear like on each others graves they are gonna walk the **** outta me... I just kinda laugh. I kinda figure it should be close, and I would edge him out. Im not trying to brag or nothing, but i am a good driver.
