Dyno'd My Stang Finally. Could Not believe it.
I got a 95 GT, with BBK cold air intake, 73 mm c&L maf, 75 mm Professional products throttle body, Professional products typhoon intake, 24 lb injectors, Edelbrock aluminum heads, E-303 cam,BBK unequal Shorties, Off-road x-pipe, Magna flow cat back exhaust. Msd ignition and blaster coil. The last time I dyno'd it I got about 250 HP and 300 Ft lbs of torque.
I bought a Diablo sport custom chip, which they burnt on the dyno. Just plugging the chip in it was at 290 HP 320 Ft lbs. It was running rich and had a dirty MAF.
Well the end result was 302 HP at 5550 RPM and 328 Ft Lbs at 4000 Rpm. Obviously to the wheels. I don't know if that seems high, but I was expecting 280 HP at most.
Thought I would share. See what you guys thought.
RE: Dyno'd My Stang Finally. Could Not believe it.
wow i didn't think a chip would make that much of a difference...
so when you dyno'd it last time did you have all the intakes and stuff.. and the chip just boosted it up to 302 hp?
or am i misreading and you added the stuff and the chip and got it up to 302? IDK
im just checking to make sure im not mistaken
chassis dyno = useless, they are so easy manipulated. I throw the wifes nissan ultima on a chassis dynop I bet it makes 300 at the tire
They are a good tuning aid, but the hp/tq number is for amusement
ORIGINAL: woodsy
ORIGINAL: mjr46
you mean ALTIMA[sm=icon_rofl.gif][sm=icon_rofl.gif]And that wouldn't suprise me if it were the 3.5 se model them suckers are fast......et is all that matters in the end right???
ORIGINAL: woodsy
Buy a chassis dyno, manipulate the machine, have a grand opening, 2 free pulls all day saturday and sunday. I guarantee I am packed up for the next 6 months with everyone wanting to blow up there junk on my new fangled chassis dyno, while I make my deposit slips.
ORIGINAL: mjr46
ORIGINAL: woodsy
ORIGINAL: woodsy
If you could explain though how they are easily manipulated please tell me.
Oh, and awesome numbers for the mods you have done, i wouldn't expect for it to break 300rwhp either. Are those corrected numbers?
ORIGINAL: TRexGAWD
I'm going to assume you don't know anything about dyno's from that statement! You obviously have no idea what a chassis dyno is, that is really the only real way to get whp numbers. You drive your car on the rollers and hammer the gas in your nearest 1:1 gear. It's also known as a Mustang Dyno and is one of the most popular ones used to date! You may be thinking of a dynapack which mounts up to the hub of a vehicle. Those usually register about ~10% higher numbers since there is no rotating mass.
ORIGINAL: woodsy
