fouling plugs
Old 05-22-2008, 01:55 PM
jeffp2152
jeffp2152's Avatar
Default fouling plugs
what would the cause of this be? too much fuel?
the car ran really crappy for about 2 months, was parked for 6, then is running again but keeps fouling plugs. is there just a bunch of gunk in my cylinders thats doing this? any cleaners recommended?
or should i just check the fuel pressure and go from there? it has a BBK adjustable fpr so that could be it...
jeffp2152 is offline
Old 05-22-2008, 02:09 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: fouling plugs
fp should be at 32psi vac unplugged.
are they fouling with fuel or oil?
FivePointOhh is offline
Old 05-22-2008, 02:39 PM
Derf00
Gentleman's Relish
Derf00's Avatar
You say gunk on the plugs...soot or oil? Oil is probably valve stem seals or rings. Any oil (smoke) out the back?
Derf00 is offline
Old 05-22-2008, 04:37 PM
VASSAGO
Banned
VASSAGO's Avatar
say someone had there stock fuel regulator, whats the pressure with vaccum on it and whats the pressure if you remove the vaccum and can you leave the vaccumm disconected with no problem?
VASSAGO is offline
Old 05-22-2008, 08:17 PM
jeffp2152
jeffp2152's Avatar
ORIGINAL: Derf00
definitely not oil, doesn't smoke much and definitely not blue smoke.
Old 05-22-2008, 09:52 PM
67mustang302
67mustang302's Avatar
Too cold of a plug heat range, not enough plug gap(maybe), too much fuel, not enough timing, weak combustion, crappy fuel.
67mustang302 is offline
BOB ROME
07-26-2023 01:54 PM
lincolnshibuya
12-08-2015 04:37 PM
firehorse02
11-16-2015 11:28 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
Quick Reply: fouling plugs
