180 thermostat help
Old 07-04-2008, 04:16 PM
bansheeyfz
bansheeyfz's Avatar
Default 180 thermostat help
hey guys
i have a 180 therm and wanted to put it in today but discovered the i cant get the bottom fastener because of the water pump. there are allen heads insted of hex heads secureing it right now i think the previous owner put them in . does any one have any advice when changing the stat out?
bansheeyfz is offline
Old 07-04-2008, 05:41 PM
droptop302
droptop302's Avatar
Default RE: 180 thermostat help
[sm=ttiwwp.gif] show me what you are talking about
droptop302 is offline
Old 07-04-2008, 07:09 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the bottom one on the t-stat is suppose to be shorter or it 'll interfere with removal of bolt and hit the backing of the timing cover..I' did that onmy 66 once and installed t-stat with intake off and used nice new shinney bolts and later I had to remove t-stat and [:@]relized I had used too long a bolt and had to usea body saw with a thin bladeto cut it in half..or remove intake if you don't like that idea
mjr46 is offline
Nick Oliver
10-17-2018 04:22 AM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
67LimeCoupe
11-25-2015 08:55 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: 180 thermostat help
