347 stroker kit
Old 07-08-2008, 12:35 PM
kjpenka1
kjpenka1's Avatar
Default 347 stroker kit
Im sorry if this is tech specific but i couldn't find the tech specific thread, it could only find the general 5.0 thread, but anyway i was wondering if i purchase the 347 stroker kit for my 5.0 what are some of the other things that i would have to modify on the car? I was thinking heads because changing the stroke must change the compression to an extreme extent. Also are there other things that i don't HAVE to modify but probably should? thanks for any input.
kjpenka1 is offline
Old 07-08-2008, 01:01 PM
Jrichber95GTS
Jrichber95GTS's Avatar
Default RE: 347 stroker kit
well if you put stock heads on a 347 your wasting the time and money that was put into that 347 should also go better intake injectors MAF TB fuel pump etc. but really you dont have to themotor would run with same stuff as it is stock but wouldnt be as much fun[sm=yeahsmile.gif]
Jrichber95GTS is offline
Old 07-08-2008, 04:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
heads cam intake , tb, cai, exhaust, gears, proper fuel system, mass air calibrated for larger injectors ,,ect ect............
mjr46 is offline
Old 07-08-2008, 07:14 PM
stang347gt
stang347gt's Avatar
^ what they said
i say go with afr 205 cc heads
trick flow intake
ford x-303 cam
30 lb injectors
good combo
stang347gt is offline
Old 07-08-2008, 08:28 PM
mjr46
mjr46's Avatar
ORIGINAL: stang347gt
trick flow intake
ford x-303 cam
30 lb injectors
good combo
eliminate the X cam and pick something better..like a dual pattern such as a comp xe series cam or xfi stroker cam or custom cam for combo
mjr46 is offline
Old 07-08-2008, 11:48 PM
jtmustang
jtmustang's Avatar
^^^ agreed the x cam is alright but their are better cams out there especially for a stroker
jtmustang is offline
Old 07-09-2008, 05:12 PM
stang347gt
stang347gt's Avatar
really?
what r some good cams out there?
b/c trickflow stage 2 cam is the same as my x cam
but if he wants it to be efi also..ford has a z-303 cam also..
Old 07-09-2008, 06:52 PM
andywear87
andywear87's Avatar
really?
um no!
trick flow stage 2.
Camshaft, Track Max, Hydraulic Roller Tappet, Advertised Duration 286/ 294,Lift .542/ .563,Ford,Small Block,Ea...
Ford Motorsport / SVO
[align=center]M-6250-X303[/align]
[align=center]286°[/align]
[align=center]224°[/align]
[align=center]0.542'[/align]
[align=center]107° / 117°[/align]
[align=center]3,500 / 6,500[/align]
but i would say a custom grind cam shaft is the way to go cause for what i spent on my cam i could have almost bought a custom cam from jay allen but the xe cams are good and the trick flow cams are decent
andywear87 is offline
Old 07-09-2008, 09:05 PM
mjr46
mjr46's Avatar
really?
letter cams were designed for the 302 in mind not 347...and stage two is not the same as x!!!! stage 2 is a dual pattern cam= better
mjr46 is offline
Old 07-09-2008, 09:09 PM
code3GT
Mustang Nazi
code3GT's Avatar
You can get by with a little smaller heads than AFR205's on a 347. I ran Trick Flow Track Heats on my 347.
code3GT is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: 347 stroker kit
