Nitrous Dyno numbers are in!
Old 07-20-2008, 07:20 AM
  #21
contentsunderpressur
contentsunderpressur's Avatar
Default RE: Doing to the Dyno tomorrow for nitrous tune!
You only picked up 73 rwhp on a 125 shot? I guess that's the down side of a dry shot.
contentsunderpressur is offline
Old 07-20-2008, 11:05 AM
  #22
bikeboy587
bikeboy587's Avatar
ORIGINAL: contentsunderpressur
[/align][/align]A) It was bout 85 degrees and 80% humidity[/align]B) Bottle pressure was only about 600-700 psi bec I didn't have the bottle warmer wired up yet. i will pick up 20rwhp when I hook it up and get it up too 900-1000 psi[/align]C) Zex systems automatically make your car run rich, 10.5ish for most ofmy runs, and the only way to lean it out is to put a larger nitrous jet in while leaving the fuel jet alone and we didn't have a larger nitrous jet to try at the dyno[/align][/align]so when conditions are right the rwhp gain will be close to 100.[/align]
bikeboy587 is offline
Old 07-20-2008, 12:28 PM
  #23
Ahhhh, didn't catch the bottle pressure being low. That means more than anything.
Old 07-20-2008, 12:36 PM
  #24
bikeboy587
bikeboy587's Avatar
it ok i forgot to mention it
Old 07-20-2008, 03:23 PM
  #25
5.0stanger
5.0stanger's Avatar
How can adjust fuel jets if it is a dry shot?
5.0stanger is offline
Old 07-20-2008, 03:34 PM
  #26
bikeboy587
bikeboy587's Avatar
The fuel jet on a dry system is attached to a vacuum line getting vacuum off the intake manifold. The zex box reads the amount of vacuum coming through the jet you have in the like to compensate the correct fuel pressure
Old 07-20-2008, 04:37 PM
  #27
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
NO2 = INSTANT torque ftw!!!! now go get some ET on it!!
mjr46 is offline
Old 07-21-2008, 12:48 AM
  #28
bighungrymatt
bighungrymatt's Avatar
very nice tq numbers!
bighungrymatt is offline
Old 07-21-2008, 02:36 AM
  #29
bikeboy587
bikeboy587's Avatar
Thanks!
Old 07-21-2008, 06:11 AM
  #30
OnyxCobra
OnyxCobra's Avatar
are you going to be spraying in 1st gear?
OnyxCobra is offline
Quick Reply: Nitrous Dyno numbers are in!
