c9te and dooe heads
Old 08-18-2008, 02:50 PM
mustangsneverdie
mustangsneverdie's Avatar
Default c9te and dooe heads
i can get either set for $246 maybe less because i work at napa which ones are gonna be better? i no mjr knows
mustangsneverdie is offline
Old 08-18-2008, 05:46 PM
FuzzyDiceRule
FuzzyDiceRule's Avatar
ive never heard of either, just spend like 600 and get GT40's
FuzzyDiceRule is offline
Old 08-18-2008, 10:58 PM
mustangsneverdie
bump bump
Old 08-18-2008, 11:24 PM
wildcobrar
wildcobrar's Avatar
I think you are going to spend more than that getting them reconditioned and depending on the camshatf you are going to need springs and possibly spring seat maching. The D0OE heads are 1970 heads the C9TE are 1969 heads. They will have small cobustion chambers and 1.78 intake valves unless they came off a 351W. The cost of guide and valve job and springs and such plus buying them is not going to be worth buying a good set of aftermarket heads.
Joe
wildcobrar is offline
Old 08-18-2008, 11:58 PM
mustangsneverdie
they are remanned so everything is good i will be getting them fromnapa
Old 08-19-2008, 07:12 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
that would be c9oe heads and the dooe heads are the same as the c9's, I'd have them lightly ported and the advantage over gt-40's is smaller cumbustion chambers
mjr46 is offline
Old 08-19-2008, 10:56 AM
mustangsneverdie
so would you do it mjr
Old 08-19-2008, 02:48 PM
mjr46
mjr46's Avatar
to me the c90e and dooe heads are only worth it if you find a set with at least 1.94 intake and 1.60 exhaust valves in them and light porting done and all this for under 400-500, I bought a set of c9's for 300 all done up just as I said from a friend as I was looking for a budget build with a little more bang and whenI was all said and done I had less than 2500.00 in the whole rebuild and the 66 stang it's in in my sig ran on street tires 13.3 @104 and I really didn't give the build much thought, and was suprised how well it performed so if you can get them as I mentioned cheap and all work done then go for it
mjr46 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: c9te and dooe heads
