Seafoam treatment.
Seafoam treatment.
So I decided to try to clean the 17 years of accumulated crap out of my Notch. Here is a pic during the process. It was horrible. Seafoam worked pretty good though, just make sure you do it before a tune up so your not messing up new plugs.
You should try it with Marvels Mystery Oil! You can't see the car, the house, the neighborhood..you might not even see the sky for 10 minutes or so. It's a bit scary the first time you do it because the smoke just keeps coming and your not sure if you f'd up, at least it was for me.
Go buy the bottles of Seafoam, read the directions. Basically what it involves is removing a vacum line and sucking half a bottle of Seafoam into the motor, then letting it sit for awhile. The starting it back up and holding it at a high idle suck the rest of the Seafoam into the motor when it's empty reconnect the vacum. Then sit in the car and hold the rpms while smoke billows out your exhaust.
Yes, it will do that and then some. Since the Seaform is pulled into the engine, while at normal operating temp, it crystalizes the carbon on the valves and pistons so it gets flaky and burns off. It will also help loosen stuck piston rings. The can states that you get 1/3 of the can in the intake system via the brake booster hose, then shut the engine off and wait 10 minutes or so and start it up. Pretty simple. Try it, you'll like it.
