locking header bolts
Old 12-24-2008, 05:05 PM
cortlan
cortlan's Avatar
Default locking header bolts
Hey guys,
I need some locking header bolts... I have mac equal length headers...
do I get these - http://store.summitracing.com/partde...1&autoview=sku
or these - http://store.summitracing.com/partde...0&autoview=sku
or should I get one of these? http://store.summitracing.com/egnsea...=KeywordSearch
If yes then which one?
I believe the lengths are different... I kind of need to order them quickly, so... whenever you all could answer! Thanks
cortlan is offline
Old 12-24-2008, 05:13 PM
Tberg725
Tberg725's Avatar
Why would you buy locking header bolts? I use the regular bolts that came with my headers and have no problems.
Tberg725 is offline
Old 12-24-2008, 05:18 PM
wrenchturner75
wrenchturner75's Avatar
as said above the bolts that come with the headers work fine, just dab a little antisieze on em and install em, now let the engine run up to operating temp and let it cool down then retighten all your bolts, you may have to do this just once or several times depending on what gaskets are used till everything stays tight.
wrenchturner75 is offline
Old 12-24-2008, 05:19 PM
cortlan
cortlan's Avatar
I have had problems with header leaks... with my ceramic headers they keep backing out.... and with the engine bay being so congested on my 94 I want to lock them down once before I put the engine back in... then hopefully not have to worry about them much after that!
Calling out MJR46!!!! you've mentioned something about these before!
anyone have more input?
cortlan is offline
Old 12-25-2008, 01:08 AM
cortlan
cortlan's Avatar
no one knows which size locking header bolts I need?
cortlan is offline
Old 12-25-2008, 01:38 AM
Tberg725
Tberg725's Avatar
Honestly I've never herd of anyone using them everyone just uses the bolts givin to them....
Tberg725 is offline
Old 12-25-2008, 01:42 AM
cortlan
cortlan's Avatar
oh... ya I've heard of people using them... just wondering which one's will fit mine... There are 4 different options/sizes for 5.0L Ford engines!
cortlan is offline
Old 12-25-2008, 08:18 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
the first set you posted will work fine = 3/8's
mjr46 is offline
Old 12-25-2008, 08:45 AM
Explosive
Moderator
Explosive's Avatar
You'd be fine with normal ones...
Explosive is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:58 PM
Quick Reply: locking header bolts
