Profesional Products Polished TB? and other build questions
Has anyone had experience with these? Their relativly afordable when compared to the BBK and I've heard good things about their intakes. I was considering the 70mm.
Side note i sold my GT40x alum heads and got AFR 165's I will be running a highly ported Cobra polished manifold and stock bottom end. I'm still undecided on cam and MAF sensor size and brand. I also need to purchase 24# injectors. I hope to have it all together in the next few weeks any suggestions would be apprecitated.
Thanks guys
Oh I need to update my sig, I currently have BBk long tubes,short x-pipe,magnaflow caback, frame ties, full suspension, PRO 50 shifter and king Cobra clutch BBK fire wall adjuster, currently eliminating smog and A/C, related components.
Thanks guys
pro products is the only throttle body i have ever owned. i had a 70mm on my last motor and this motor has a 75mm. they are fantastic. never sticks, the tps has a huge range of adjustment. very good piece
Had a bunch of them that would stick (all within a 6 month period) but kind of stuck to BBK after that. Never a problem with any BBK. I even had an Accufab that had some issues. I know of a lot of the PP out there with no issues. I think the ones I got that stuck were just all in a bad run. I just couldnt afford to keep replaceing them on customer cars so we discontinued using them.
I bought a PP throttle body for my Cobra. It looks okay but i had to redrill one of the holes so it would bolt up to my intake. I also had to adjust the throttle blade because it kept getting stuck inside the housing. After fixing all of that it's a decent TB.
Thank you all for your input, PP TB sounds like a winner to me I'll take my chance's with it.
Any recomendation on MAS size and brand. I was thinkin P&L 73 or 76 as far as cam goes my original intention's were just an aphabet cam.
