So...after having this car for awhile now, I finally want to start putting money into it. I offically finished the 240sx build resulting in a 400hp 387ftlbs of torque with a 3071r turbo upgrade(from the gt28r) and bigger injectors, SAFC, fuel rail and some tuning. Now on to the muscle!
For the H/C/I set up, is a new Trottle Body recommended as well? Will I need to advance the timing a wee bit to handle the E303 cam or can I just slap the cam in and run it with out any tuning? Headers and exhaust is easy enough.
Sub frame bushing replacement is a must cause the is a flex-o-rific 'Vert. Rather then just getting lowering springs, it would be better to get struts as well, correct? Obvious answer is 'yes' but what are you guys running?
And go figure...power steering pump is goin tits up. PLUS leaking from the rack. Can I just replace an O right within, or is a rack and pinion set up replacement recommended?
I am mysteriously losing water as well. Gotta fill er back up every 3 weeks or so. Gotta look into that...
Thanks for your time
__________________ 400hp, 383 ftlbs KA-T S13.5 Nissan 240sx
GT3071r Turbo/264 Cams/8:1 Compression/Arias Pistons, Corillo Rods/550cc Injectors/ROM Tuned ECU/Apexi Neo SAFC/Full Exhaust/Walbro 255 pump 89 GT 5.0 Vert DD, mods on their way
