What size spark plug wires should i get
Old 02-13-2009, 08:14 PM
crusin92red5.0
crusin92red5.0's Avatar
Default What size spark plug wires should i get
i see that there are different size wires and i was wondering what size wires should i get? 8.00 mm, 8.20mm, 10.4mm? My mods are in my sig and i'm pretty sure i'll go 347 in a year. (the year will start as soon as i can get the damn thing perfect).
10.4mm
8.2mm
8.00mm
The wires i have on there now have probably less than 200 miles on them but are a few years old.
thanks
crusin92red5.0 is offline
Old 02-13-2009, 08:53 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Get some FR 9mm wires. Cheap but good. That's what I run.
PRO50SC is offline
Old 02-13-2009, 09:37 PM
crusin92red5.0
yeah i here good things about FR and then i here bad things about them so i'm floating around again, since you use them and lets just say your's isn't stock . i saw you found a good place for injectors (i booked mark that ) what about wires?
Old 02-13-2009, 09:56 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
^^^I second that one
mjr46 is offline
Old 02-14-2009, 07:17 AM
Timspony
SVT Section Moderator
Timspony's Avatar
I third it! FRPP wires the best bang for the $$$ ...I did have the Taylor 10.4's, good, but $$$$
Timspony is offline
Old 02-14-2009, 08:23 AM
BlessedHellride
BlessedHellride's Avatar
I had a pricey set of 8.8mm wires on the car when I built it. When I went to the track the first time, I would remove the hood after every pass to inspect the powerplant. After my 2nd pass, which was my first 11.92 run, I found the number 8 plug wire was laid over against the header primary with a nasty burn mark on it and I could tell it was firing against the primary tube. I sent the Warden over to the local parts house to pick me up a set of wires to get me through the weekend at the races. She came back with a cheap set of Car Care 8.0mm wires. I put them on the car, next pass was a 12.30, my fault, I stumbled the car out of the hole. Next pass was an exact duplicate 11.92 @ 113 mph pass as before. Since seeing this, I haven't changed them out. Still running the cheap plug wires from Car Care.
BlessedHellride is offline
Old 02-14-2009, 09:28 AM
S-Trimmed302
S-Trimmed302's Avatar
For the $ you cant beat the FMS 9mm Wires if you want something more Pricey go with the Taylors with the heat shields that will protect them from touching the headers.
S-Trimmed302 is offline
Wesley1995
08-30-2015 02:01 PM
overnight89
08-22-2015 09:02 PM
Philhampton1
08-21-2015 12:04 PM
microgt
08-20-2015 07:12 AM
Quick Reply: What size spark plug wires should i get
