Me vs. my buddy...question
Old 04-11-2009, 11:45 PM
gt96blue
gt96blue's Avatar
Default Me vs. my buddy...question
Today my buddy and I were havin a little fun on the highway and decided to run 1 time for fun. Question though. He has a STOCK '02 GT accept for weld in flowmasters. Now I have a '90 LX with the following mods: 306, longtubes, o/r h, slp lm1, pullies, cai, explorer heads/intake, e-303 cam, 3.73's, sub-frames, springs, and both cars are 5-speeds. We went from a 3rd gear pull through 4th and were neck and neck the whole way. Does this sound right? I'm just asking because I was thkning I was quicker but maybe those new edges are faster than I thought. And we are both "good" drivers(in my opinion lol).
Thanks for any input
gt96blue is offline
Old 04-11-2009, 11:54 PM
jthorn9
The Godfather
jthorn9's Avatar
Well put it this way, 99-04 GTs dyno at around 230 rwhp, I dynoed today at 240 rwhp with similar mods than you, however no cam but better h/i, so that sounds about right depending on how good/bad your a/f ratios are. My car is running really rich killing some of my potential power, 99-04s also run a little on the rich side factory, but still not nearly as bad as 05+ which can run as bad a 9s on their a/f where a good number is high 12s low 13s, I pulled around low 11s today (higher the number the leaner the mixture).
jthorn9 is offline
Old 04-11-2009, 11:55 PM
KINGKAOS
KINGKAOS's Avatar
I'm curious to know this answer as well..
KINGKAOS is offline
Old 04-12-2009, 12:01 AM
jthorn9
The Godfather
jthorn9's Avatar
In short, yes it's probably about right, you have the edge though, however, a lot of other variables go into the equation as well, but generally it's going to be a closeish race at this point.
jthorn9 is offline
Old 04-12-2009, 12:38 AM
NoGo95GT
NoGo95GT's Avatar
You should have easily won. Something is amiss.
NoGo95GT is offline
Old 04-12-2009, 01:15 AM
OnyxCobra
OnyxCobra's Avatar
did you get your car tuned after your head/cam/intake swap? Also try racing from a dig, chances are you'll pull him off the line and he won't be able to catch up.
OnyxCobra is offline
Old 04-12-2009, 01:24 AM
KINGKAOS
KINGKAOS's Avatar
Thats what I was thinking... But wanted to "know" for sure... (I'm new to stang's..Less then a year..) Thanx!
KINGKAOS is offline
Old 04-12-2009, 06:12 AM
jthorn9
The Godfather
jthorn9's Avatar
Also, have you ever had it on the dyno; if not, you really should hit one up, they can tell you a lot about what's going on under the hood, and the areas you need to look at to fix any problems to maximize power.
jthorn9 is offline
Old 04-12-2009, 06:57 AM
Baddog
Baddog's Avatar
Goddamn right, unless your car is struggling to get on tune you have more than enough to stride on a New Edge with solely a catback...
Baddog is offline
Old 04-12-2009, 12:54 PM
gt96blue
gt96blue's Avatar
Here's the deal. When i bought the car it already had the heads/cam/intake, pullies, and 3.73's installed. Since i bought it i had it bored to a 306, did the exhaust and the cai, sub-frames, and springs. So honestly i'm not sure if it has ever seen a dyno. Should that be my next move...gettin it on the dyno?
gt96blue is offline
Quick Reply: Me vs. my buddy...question
