Ok well scene i got the T5 in the car ive had this odd issue where when i first start the car it wont go in any gear but reverse, Ive had to rock the car back and let it roll forward then it will slide into first, then no other issues after that.
Well the clutch has been adjusted 3 time's to try and fix it, ive thought up every issue, contacted promotion powertrain who built it and they said that it was a mis-installed throwout barring....
well just about 30min ago me and the gf go out to get some food, same issue, no gear other then reverse, so while im waiting for the car to warm up a little more, and im messing with it trying to get it to go into gear, i bap the throttle it sweep's just past 2krpm, and just so happen at the same time be messing with the shifter, and it went right into gear!
i pulled it back out of gear, and it went right into first, second, third, forth and fifth no issues, SMOOTH.
We go to leave subway, i back out of the spot i was in, go to put it into first and it wont go. It doe's this sometimes and i have to let the car roll forward a little, and it will slide in.
Well instead of that, i tap the brake, putting the car to a stop. rev the car past 2k rpm, and it slide's right into gear!
why would this solve the issue? i dont get it?
reminds me of "old school" transmission's ive heard about where you always had to rev-match them to get them to shift smooth.
would like to know what you guy's think about this.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
do you have a stock quadrant? and just a firewall adjuster?
you can adjust the firewall all you want with a bad quad it slips and your clutch drags and you have this problem till it warms up or its able to slip.its that or you have a pos rebuild theres only 2 ways to install a throwout with the clip in the wrong or right spot. did you do the work yourself?make the builder fix the problem if its not your fault instaling it then its theirs.t5s are simple but if you leave out stuff on a rebuild you could have al sorts of problems. check the fluid level if its leaking and empty this will cause this too. and when u burn up the cobra get a 4banger t5 and diesel ranger pilot bearing you will thank me later
__________________
86 MUSTANG GT, t5, maf,bbk underdrives,taurus 3g alt, contour dual e fan,crane cams ignition/coil,mac equal length shortys, off road h pipe, flows dumped. 5 lug infront so far
93 JEEP GRAND CHEROKEE LAREDO 4.0 NP242 lifted
88 HONDA PRELUDE 2.0SI 4WS (four wheel steering to the uninitiated)
not meaning to thread jack by why use the 4 banger t5? is there something different between those and the v8 t5? I was always under the assumption the 4cyl t5 wasnt meant to handle **** for power. Please correct me and inform me if I am wrong or have been misinformed.
__________________
They call me Organized Chaoss... Some food for thought
Mods: I dont have a friggin clue... I bought it from a hack job and now its up to me to fix it! Gotta love people.
Quote:
Originally Posted by AdderMk2
deep down inside, he's a mullet growning redneck
just refuses to admit it.. sorta like being a closet fag
the 4banger t5 has better gear ratios there in lies the reason it handles less power plus its said to use crappier metal but even the the v8 t5 is underrated at 260ftlbs of torque and i think the 4 is rated at 237ftlbs neither are a good choice for a stock motor making 300ftlbs from the factory. the 4 banger t5 has a slightly smaller pilot shaft so the ranger pilot solves this. the input splines are the same so it can be used with a stock v8 clutch. switch the belhousings and its all good. drives like you just upgraded you rear gears! and the best part is there cheap and not abused like a v8 one. i mean a 89-113hp 2.3l isnt going to put the kinda wear a 225hp v8 will on a t5.i had a 93 cobra t5 i destroyed it . it wasnt any nicer than my original v8 t5 for the most part. the 4banger is a great bang for your buck
__________________
I'm sorry, but it just sounds like ticking time bomb with a shorter fuse than the V8 T-5. I've had my same T-5 since I've owned the car. It's been behind the stock engine and the stroker. It was rebuilt once, before I owned it, and that was 7 years ago at least. It depends on how you treat them. Besides, aren't you the guy who made that contraption with license plates?
you do not want a 4 popper tranny , btdt!! with 3.73 gears and the 4 cyl tranny it felt like a road race tranny and went nowhere quick....most likely those who love it often have no rear gears added into the equation so yes with a 4 cyl tranny and 2.73 or 3.08 gears then it may feel like you had something..lol
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
have you had a car with one???its very simple look at the specs and drive it.with stock rear gears, and who has 3.73s except aod cars? so why would it be a problem.so just admit it i....with stock gears like 2.73 a 4banger t5 will improve you gearing!
__________________
im pretty sure MJR has since in his statement he said "btdt" which = been there done that
anyone that puts them in their car? its actually a pretty common mod on these cars, expecially for a t5 stang since its the recommended gear ratio. generally AOD are recommended to have 410's
and thats exactly what he said the first time. you just said the same thing a different way.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
Did you not read my post Brett?? BTDT= BEEN THERE DONE THAT.....my 92 was a 4cyl conversion ...not sure what you mean by "who has 3.73 except aod cars"??? stock FACTORY never offered higher than 3.27 gears in the run of the mill 5.0 and those were aod equipped ones often.....read the last sentence in my original post and compare it to what your last sentence states.....understand now??
__________________
