Grudge match
Unless you get some gears in that thing he's going to beat you like a red headed step child. The thing you want to do is go out of town to have the gears done and throw in a Nitrous kit (100shot) and don't tell anyone (not even the dog) and when track day comes bust his bubble. I use to have guys drive 125 miles to have gears and Nitroius installed on their day off just so their friends wouldn't know anything about it. Learning to keep things under wraps are the secret to opening up the can of whoop azz on your buddies.
To OP.
I'm going to throw in the weight difference into this battle. I'm sure I'll catch grief from the SN guys but yo unever know until you try. Also, was that an E303 on stock heads? According to the masses around here, that makes you slower. Not less horsepower but losing that bottom end as thay say... Finally...3.08s are a touch better than 2.73s Run it!
When he goes to the port a john at the drag strip pull of an ignition wire from each side of the block. :P But, I don't see you winning. Is his a vert? They are a little fatter. Last year at the track I beat a vert w/ 4.10s when all i had was pulleys/catback. Both stock motors with t-5's.
mungodrums
Suspension
02-09-2016 09:05 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
