msd 6al install
Old 05-07-2009, 01:33 PM
mustangt95
mustangt95's Avatar
Default msd 6al install
i have installed my ingnition box in the trunk andran the wires to the front increasing wire guage as it went, my question is when its in use my car doesnt run right, its at 10 degrees timin before idk what it is after but it idles hard and misses.
someone had suggested to me that you have to unplug the tfi ignition module and the msd box will control everything. is this possible?
any help will be greatly appreciated
mustangt95 is offline
Old 05-07-2009, 01:43 PM
joeymustang
joeymustang's Avatar
how do you have it wired?
joeymustang is offline
Old 05-07-2009, 07:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I believe the tfi needs to remain plugged in, mine is and it runs fine
mjr46 is offline
Old 05-07-2009, 08:00 PM
luckythirteen13
luckythirteen13's Avatar
tfi needs to be plugged in. its how the computer controls the ignition system. if you dont believe me unplug it, the car wont start.
check to make sure you didnt cross any wires when you did the install
luckythirteen13 is offline
Old 05-07-2009, 09:47 PM
mustangt95
mustangt95's Avatar
its wired fromthe trunk along driver side to engine. i purchased the msd harness that goes inbetween the coil and the wireing harness.
it just dont seem right somehow but i checked the wireing the instructions of all thinks
Old 05-07-2009, 10:21 PM
AdderMk2
Banned
AdderMk2's Avatar
you wired something backwards
AdderMk2 is offline
Old 05-07-2009, 10:49 PM
mjr46
mjr46's Avatar
go through it again and check all wiring!!!
mjr46 is offline
mtgldr
02-03-2024 09:00 PM
BOBCATJACK
09-14-2015 02:18 AM
09-10-2015 08:39 PM
Quick Reply: msd 6al install
