this is Bob's wife he is installing his motor today and an hour away from me
it's a 306 with AFR 165's with custom ground cam, he is not sure what his timing should be set at
if someone could please advise me I am on via speaker phone with him~!!!
PLEASE HELP ME>..
Thank you so much for any help..
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2004 SVT COBRA Black 495RWHP 530RWTQ
2004 F250 SD CC Diesel Black on Black, lifted.....
Vehicle: '97 #240, Saleen Speedster and '69 Mustang Sportroof
Tell him to set initial timing with a vacuum guage. With the Vacuum advance to the distributor plugged. If it knocks after the vac. advance is hooked up, retard the initial timing 1 degree at a time until it no longer does.
Eric
Nice try but reply = fail........he has a sn-95 mustang = sefi not carbed...anyway to the op.....pull the spout connector set base to 10 degrees via timing light pointed on the balancer , stock spec = 10 btdc......then advance from there, I run mine at a base of 13...........once set, shut car off and reinstall spout connector and be on your merry way
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
OK guys i didnt even get the dist installed last night so she isnt even running yet. I had some troubles with the install so things arent as far along as i anticipated..
I dont understand what you mean by spout connector. Could you please explain?
Thank you again for your help..
__________________
Running off your drivers side fuel harness (plugs that go onto your injectors) you'll notice at the end (closest side to front bumper) that there's a little black square box and inside of that is a little gray "spout" that gets taken out when setting your timing.
__________________ Trickflow Street upper/lower intake for sale 325$ + shipping!
