FMX Trans
Old 05-17-2009, 02:54 AM
Ryan Suchey
Ryan Suchey's Avatar
Default FMX Trans
I took my T-5 out and replaced it with an FMX trans. I was woundering if anyone could tell me what shifter would do best. I would also like to know about the linkage, will the brackets for the c-4 or c-6 work, as far as hooking up the shifter cable.
Ryan Suchey is offline
Old 05-17-2009, 06:41 AM
Gary H
Gary H's Avatar
Why an FMX? Those things are HEAVY and not alot of parts for them. A c4/c6 shifter isnt going to work unless you can figure out a way to run the cable around to the front og the lever on the trans. It can be done, but it will take alot of work. Do a search on the net and you'll see what I mean.
Gary H is offline
Old 05-17-2009, 06:59 AM
Portmaster
Portmaster's Avatar
Better get some subframe connectors cause you car is going to sag in the middle with that cast iron tranny, lol
The C6 linkage or the C4 won't work if you are using any kind of cable shifter. Your best bet would be to buy a cheap universal mounted shifter like the Hurst IndyMatic and modify the brackets to go on. I know this will work because I did a few floor shifter conversions back in the 70's on some galaxies with the FMX.
Portmaster is offline
Old 05-17-2009, 07:15 AM
BlessedHellride
BlessedHellride's Avatar
My advise would be to pull that FMX out and haul it for scrap and use the money and put it towards a C4 or C6
BlessedHellride is offline
Old 05-17-2009, 12:05 PM
uedlose
uedlose's Avatar
FMX are not the best trans. gone and suffer from lack of performance parts. and like said they are very HEAVY. a C-4 is twice the trans. of a FMX.
uedlose is offline
Old 05-18-2009, 09:40 PM
Ryan Suchey
Thanks for all the input. I hope I can get it all back together. If not I wil have some srap iron to haul off.
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
2poor4u2
09-26-2015 11:08 AM
97SN95GT
09-13-2015 09:45 PM
Quick Reply: FMX Trans
