TPS question
TPS question
OK, forgot some basic knowledge. Which wire on the TPS do you check voltage on to tweak it and what is the optimal voltage? Had a 63 code (low TPS voltage) so I replaced the sensor...now I get code 23 (TPS voltage outside test specifications). Funny thing, the car ran fine for about seven hours after switching sensors...then went back to a low idle and choking at traffic lights. Help...I've already pissed off a Viper and two Corvettes that thought I was popping the gas at 'em...lol!
Thx for the info Joel. It doesn't stall now. Still have a slight rolling idle, but my new 75mm TB doesn't have an I/A bypass plate like my 70mm did. That should fix that. WTF happened with those things anyway...they were 12 bucks back when I bought my first 5.0. Now they're $35 and you're lucky if the dealership knows what you're talking about.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
