Good deal for this intake?
It is a reasonable price. Make sure there are no cracks. Victor 5.0 (4000-7500 RPM)
Intended for 5.0L-based competition EFI engines and other modified 400 to 540+ HP engines, this aluminum EFI intake manifold is for non-emission racing applications and features shorter (11.5"), larger (50% more area) runners for power to 7500+ RPM. The air-gap base isolates manifold from hot oil and accepts stock/stock replacement fuel rails. Upper manifold clears tall valve covers and large fuel pressure regulators. 1994-95 Mustangs require conversion to 1987-93 inlet system. The Victor 5.0 manifold is designed to work with Edelbrock Victor Jr. #350-77179 or Victor #350-7721 cylinder heads. Fel-Pro Intake Gasket #375-1262 and an Edelbrock 75mm throttle body (for most applications) are recommended. Larger injectors may be needed depending on horsepower levels.
what all do you have done to the car? cause if its pretty much stock, that intake wont help you that much! probably will hurt you, But that is a decent price, like stated above make sure there arnt anycracks
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
