Ford Mustang Forums - Ford Mustang Classifieds - MustangForums.com Photo Galleries - MustangForums.com Chat Room - Create an Account - Mustang News - Mustang TSB
Go Back   MustangForums.com > Ford Mustang Tech > 5.0L (1979-1995) Mustang > 5.0L General Discussion
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-02-2009, 12:08 AM   #1
mustang283
Vehicle: 1991 ford mustang gt
Default What heads to get for 331 stroker w/ x303 cam?
ok, i just reciently bought a 1991 mustang gt for 3000 dollars. All it needed the guy said are the heads, injectors, and mass air meter. This is what it has...
Hawks racing 331 bottom end w/ main cap girdle
racing pistons w/ flat top design
explorer intake manifold
70mm throttle body
255lph fuel pump
voss performance cold air kit
x303 camshaft w/ upgraded valve springs
These are the things that I know. I was told the next thing I need to do is get better heads. 1st off does this look like a good setup? I have did research all day and have no clue about most of this. I was thinking about getting edelbrock performer 170cc heads. But is 170cc enough for that cam and the 331 stroker? The guy that sold it to me said he was gonna eventually put a 210cc procomp heads, but i was told by many that 210cc is WAY to big of heads.
Any help is GREATLY appreciated! I've been researching this forever and can't find what heads to get for my stang.
THANKS!
mustang283 is offline   Reply With Quote
Old 07-02-2009, 03:02 AM   #2
83gtragtop
83gtragtop's Avatar
Vehicle: 1983 Mustang GT Vert 1 of 1001
Those Edelbrock heads are much too small. Better off getting a set of either AFR 185/195's or some Trickflow High Ports. From there I recommend a custom cam to tie the whole setup together, Camshaft Innovations has been used very sucessfully on this board. The X303 is going to be costing you some power.
83gtragtop is offline   Reply With Quote
Old 07-02-2009, 06:44 AM   #3
Joel5.0
Joel5.0's Avatar
Vehicle: 1986 Ford Mustang GT
TFS TW 170's or 190's "fast as cast" + CI custom cam combo..... upgrade that intake and you'll end up with a little street monster capable of running low 11's N/A. And no.... 210cc heads are not too big for a 331 or a 306...... it's the whole combo that needs to be set correctly to benefit from better flowing heads.
__________________
ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 GT-X303-289 heads-1.72 rockers-RG 4+1 Trans.
Quote:
Originally Posted by Joel5.0
Great thoughts will overwhelm a feeble mind.
There is never money to do it right, but there's always money to do it over.
The proof of understanding is the ability to explain it. (H. Torruella)
Joel5.0 is offline   Reply With Quote
Old 07-02-2009, 11:21 AM   #4
mustang283
http://cgi.ebay.com/ebaymotors/289-3...lenotsupported
are these crap? And what specs should i get if i get 185cc for the internal chambers and stuff?
and what specs should i get if i get a new intake manifold? how would i make it match the heads?
Thanks everyone for your help, and i just want to have the fastest car on the street and use the power ocasionally when messin around with someone.
Old 07-02-2009, 11:52 AM   #5
83gtragtop
83gtragtop's Avatar
Listen to his advice.
vvvvvvvv
Old 07-02-2009, 12:26 PM   #6
luckythirteen13
luckythirteen13's Avatar
Vehicle: 92 hatch
stay away from procomp heads. i run a 205 heads on my 331 thats been ported to about 210 so they arent too big. 170 will be too small for a 331. try looking at some of the better heads like TW or AFR. you can get them used at a good price over on corral any day of the week
__________________
6.90 @ 103.61MPH with a 1.65 60' on low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 07-05-2009, 10:54 PM   #7
tinman
Vehicle: 84 Mustang, 59 Ranchero
TFS heads/valvegear are THE way to go as long as you are running hydraulic roller stuff. Not only on here but on other boards there is not a lot of good news about 'Pro-Comp' heads, made in China by chinks anyway.............
__________________
GOOD,FAST, CHEAP-----------YOU CAN ONLY GET 2 OUT OF 3!!!!!!!!!!!!!!!!
tinman is offline   Reply With Quote
Old 09-10-2009, 12:22 AM   #8
mustang283
Okay, i've been reading alot...
And I have decided to get the following for my mustang.
24lb injectors
78mm mass air flow
BBK shorty headers
And the next part is the intake / head /cam combo.
I already have the x303 cam...
If I get the AFR heads 185cc will they bolt right on without having to notch the pistons or anything? And I was going to get a Edelbrock performer RPM ll intake.
Old 09-10-2009, 06:57 AM   #9
mjr46
Wal-mart lube/tire tech
mjr46's Avatar
Vehicle: 85 mustang
depends on your piston valve reliefs and what they are currently, 185's are a decent choice, I run them on my 347, as for your injector size and cam choice for a stroker
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 09-10-2009, 01:20 PM   #10
mustang283
Well, I still have the stock heads and gt40 intake on my 331 stroker, do you think it would be ok to go ahead and put the 75mm mass air and 24lb injectors on? And put the heads and intake on a little later when i buy theM? Would I notice a difference in anything?
060, 185cc, 331, afr, cam, explorer, ford, heads, injectors, intake, mustang, reviews, specs, stroker, x303
Featured Sponsors
Mustang Accessories
- Mustang Exhausts
- Mustang Mats
- Mustang Seat Covers
- Mustang Car Covers
- Mustang Head Lights
New Sponsors
Advertising Information - Contact Us - Ford Mustang Forums - Archive -
Top
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
