New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-02-2009, 11:11 AM   #1
cholericfc
1990 Ford Mustang
cholericfc's Avatar
Vehicle: 1990 Mustang GT
Default Shop screwed me - I feel like I got robbed.
I replaced the entire steering over the last week. I call up the shop on Sunday night and guy the guy says, "we can get your car done on Monday" Well, I show up Monday morning and the mechanic personally tells me that the guy made a mistake because they were booked solid. I tell him I can be flexible. Well, I had a box on the passenger seat with things in it, oil, oil filter, directions to the caster/camber plates - so he could read the settings. Well, I tell him to use everything in the box. HE DOES - except he DOESN"T use the JAM NUTS. (( I couldn't get the jam nuts off the old rack, so I took a saw and cut the inner tie rod in half, so the old tie rods/jamnuts were sitting in the box))
SO THE MECHANIC TELLS ME ITS MY FAULT. HE said, he set the toe-in and the last thing he looks for to tighten up is the jam nuts. he said the damage had already been done, and if I want to have the jam nuts put on, it'd cost extra.
I PAID $96.00 for a 4 wheel alignment too. I couldn't even get a 4-wheel alignment done on that car anyways. BOTTOM LINE; the only reason why i wanted them to do, is because their honest with their alignments - no pencil alignments!!
I THINK THATS BULL-SHAT THOUGH... THEY SHOULD REMBERSE ME MONEY$$$ OR PUT THE JAMNUTS ON AND RESET THE TOE ----- DON"T YOU THINK?????
__________________
302 Crate w/ B-cam, Gt-40 heads; Flowmaster exhaust (no CATS); 70mm MAF; Edelbrock Manifolds; 24lb. Injectors; 155LPH Pump; Mishimoto Radiator; 3G Alt; MSD Coil; 3.90 Gears; Subfr. Connectors; Brand new Suspension
cholericfc is offline   Reply With Quote
Old 07-02-2009, 11:13 AM   #2
cholericfc
1990 Ford Mustang
cholericfc's Avatar
oh yeah, I used everything in box BUT the SAWED--jamnut/tierod--assembly.... how come he knew to use everything else???
__________________
Old 07-02-2009, 12:01 PM   #3
Tony71502
Tony71502's Avatar
Vehicle: 1991 Ford Mustang
The new rack didn't come with the nuts? Thats beat.
Honestly, without specifically telling him to install the old jam nuts on the new tie rods, I can understand him not doing it. Even though it takes a real crackpot to assemble a steering system without such nuts.
If my car is ever out of my hands, like getting body work or somthing that I don't care to do and would rather pay someone to do for me, I basically write out a list of what needs done/precautions when handling the car. Then I tape it to the steering wheel.
Also, I try to talk to my mechanic before/when I drop the car off so he's on the same page as me.
You can never underestimate people.
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
Tony71502 is offline   Reply With Quote
Old 07-02-2009, 12:26 PM   #4
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
if you want it done your way, do it yourself.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 07-02-2009, 02:14 PM   #5
camaroeater
camaroeater's Avatar
Vehicle: 1988 Mustang GT
yea, he blames you b/c its his fault. If they had any pride at all, they would fix it. That sucks, i hope you get this staightened out. I got ripped off from a shop not long ago and thats when I knew I had to do the work myself to be satisfied.
__________________
Mac CAI, 65mm TB, Explorer intake, BBK Shortys, BBK X-pipe,
Magnaflow catback, UD pullies, Timing @ 13*
camaroeater is offline   Reply With Quote
Old 07-02-2009, 02:18 PM   #6
Tony71502
Tony71502's Avatar
Not to mention you pay 1/3 the of the total price ( just parts instead of parts + labor) and you can usually get a higher quality outcome when you do it yourself. Unfortunately some things do require professionals.
__________________
1991 LX 5.0 5Spd
Tremec T5
MM Suspension
Old 07-02-2009, 02:19 PM   #7
86 5.0L
86 5.0L's Avatar
Vehicle: '86 Mustang GT
I just found a shop were the guy is really passionate about his work, and cheap too, MX FTW
__________________
Car: 1986 Mustang GT Hatchback || 5.0L H.O. || Borg-Warner T5 || 148,000 Miles || 25mpg
Mods: Bfg Traction T/As || Front sway bar || K&N/silencer removed || Hood pins
Times: faster then a speeding Prius
86 5.0L is offline   Reply With Quote
Old 07-02-2009, 02:23 PM   #8
a_penquin
1998 Ford Mustang
Vehicle: 1998 Ford Mustang GT
Send a message via AIM to a_penquin Send a message via MSN to a_penquin Send a message via Yahoo to a_penquin Send a message via Skype™ to a_penquin
I had that happen when I had a shop fit the xpipe on mine. I put in the headers and cat back then sent it to them to fit the xpipe. Told them what I wanted and they kinda did it, after the second trip and complaints. The guy forgot to mount a hanger to keep the weight off my headers after I cut the one off my old xpipe and rigged it to wok with the new one. At least when I came back to complain they took it right in and did a no cost to me fix, and a one year warranty against defects and loose hardware
__________________
98 4.6 SOHC GT
MSD coil packs, Headman street headers, BBK X-pipe w/cats, Cherry Bomb vortex cat back, ZOOM clutch, Auto Meter 3 pillar w/oil press, water temp, and volt gauges, Alpine head unit. work still in progress.
a_penquin is offline   Reply With Quote
Old 07-02-2009, 04:58 PM   #9
PRO50SC
What the problem is???
1992 Ford Mustang
PRO50SC's Avatar
Vehicle: 92 Notch Procharged!
Send a message via AIM to PRO50SC
Why did you pay for an alignment that can't be done. That was ignorant on your part. As far as the jam nuts go, he could have simply removed the outer tie rods counting the turns, installed the jam nuts and reinstalled the tie rods w/o disturbing the finished alignment.
__________________
92 LX NOTCH PROCHARGED
DRIVE IT LIKE YOU STOLE IT!!!
ROTM 08/06
11.761 run from 4/4/09
See my Movie
Wheels up!!
PRO50SC is offline   Reply With Quote
Old 07-02-2009, 09:19 PM   #10
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
No offense but I fail to believe your telling the whole story here, your only saying what you want to support your perspective, I 'm sure the shop has a perspective too, and the truth lies somewhere in the middle, BTSTDT......YOU HAVE A SOLID AXLE, in the rear so I'm sure you know only front wheel alignment can be done, and something that doesn't jive in your post is you state you had to cut the tie rods off to get the old jam nuts off?? so was that before you brought the car into them?? or after?? I would assume before cause i DON'T SEE HOW THEY COULD EVEN ATTEMPT an alignment with frozen jam nuts........So I assume you had a new rack for them with new outer tie rods and jam nuts to install???....if that's the case why wouldn't you have assembled it at home and handed it ready to go to them??? see what I mean??...your story has to many holes.........your not telling all.....so I won't ASSume anything.....also when the shop says "the damage is already done ....what damage....clear this story up and fill in the blanks, cause the way you paint the picture of the shop doesn't jive with anyone who'd do work as such that is competent........trust me I deal with such situations everyday of the week.
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
alignment, car, cholericfc, end, frozen, jam, nut, robbed, rod, screwed, tie, wheel
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
