right now i have stock mass air meter and stock 19lb injectors and a 255lph in the tank, what size injectors would be recommended for a s/c?
i am also looking to get one of those C&L power pipes instead of the mac fender well i have, i have heard good things about the power pipes with a s/c setup, chime in if you know anything about them
why don't you buy kweeb's supercharger. He seems like a good fellow. Plus his still has warranty I believe.
Here is a link to the injectors. http://buyfordracing.com/ 209 with free shipping you can't go wrong. It is where mine came from too.
what size injectors do i go with a setup like that, my buddy works for a ford dealership in the parts department and a guy i know is in charge of the frpp stuff
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
When buying supechargers, I would buy used. It's what I did, plus you will save lots of $$$, especially since you have a Fox. Corral.net is a good place to check out. You will need 42lb injectors, a bigger MAF(the 90mm Lightning MAF works great. $90 NEW on Ebay) and a tune. For more power I would get a smaller SC pulley and a powerpipe from UPR or AFM. My preferance is Vortech V2. It sounds good and makes good power. With everything you should hit 450rwhp w/slightly less torque.
__________________
95 Mustang GT
TrickFlow H/C/I + AODE + Vortech SQ@16psi + Tweecer Tuned by Fritz Kloss
New Dyno #'s: 396rwhp/431rwtq(ran out of fuel)
New ET: 7.57@91 (1.84 60ft) http://www.youtube.com/watch?v=el5XYPGj4sM&feature
DD: 95 Mustang GTS- 5 spd; 306ci, Magnaflow X, Summit headers, Pypes Cat-back, K&N, MGW shifter
New ET: 9.7@72(2.34 60ft)
Thanks alot for the info, yes i will be picking up 42lb injectors, i was looking at the v3 since it's internally lubricated and i dont need to run lines
also for the power pipe i was checking out the c&l 76 with 42 lb mass air flow calibration would this be fine?
