Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-20-2009, 09:55 PM   #1
1slick88cat
Vehicle: 1988 mercury cougar
Question :confused: is this 306 a deal or no deal
i found a 306 engine with trick flow bottom end, bored .30 over xxx mexican block, 10.5 to 1 compression, polished crank no heads, custom ground cam with .576 lift for low boost has dyno sheets that said it made 300 on motor 450 with supercharger(twisted wedge heads) block was machined and hot tanked magnafluxed and fully prepped
i know i will blow somthing in my stock 5.0 when i install a 11 psi superchargerand intake, powerpipe, the stock one has 98k miles but not that long ago it had new gaskets installed
he wants $1100 for the 306 is that a good deal even though i would have to spend money on good high performance heads
1slick88cat is offline   Reply With Quote
Old 07-20-2009, 09:57 PM   #2
Creetan
Vehicle: 1989 LX Coupe
You say it's 10.5 to 1 compression yet it's made for boost? Something isn't right there. Dyno sheets prove nothing when u are buying just a motor from an individual.
__________________
89 Coupe
347 beast coming soon!
Creetan is offline   Reply With Quote
Old 07-20-2009, 10:06 PM   #3
1slick88cat
is tat alot of compression for a supercharger
Old 07-20-2009, 10:11 PM   #4
Creetan
yes it is.. Most people build a motor with a compression of about 8.5 -9.0 to 1 for boosted applications. 10.5 compression is usually an all motor set up.
__________________
89 Coupe
Old 07-20-2009, 10:40 PM   #5
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
$1100 for a shortblock is a bit much...
also, XXX isnt a mexican block.
i would probably skip this one
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 07-20-2009, 11:01 PM   #6
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
wrong section!!..this is tech
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
306, 5.0, cougar
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
