Should I upgrade to 31 spline?
Hi
I am going to be installing some 3.73's and rebuilding the traction loc at least. I was wondering if I should upgrade to 31 spline axles and differential?
I will be building a 347 stroker and will see mostly street abuse, will the 31 spline be overkill?
Thanks.
Thanks.
ok, thanks for the input. I might as well do it right the first time around and upgrade to the 31 spline.
So what all needs/should be replaced when I am building this rear?
So far I have the following on my list:
-Ford Racing 8.8' Traction-LOK Limited Slip Differentail - 31 SPL (would you recommend carbon fiber clutche plates?)
-steeda 31 spline axles
-8.8 3:73 ring and pinion
-8.8 axle girdle
-and an installation kit(axle shaft bearings, axle shaft seals, pinion gear bearings, carrier bearings, pinion and carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts and cover gasket.)
I know I need fluid as well.
Am I missing anything?
-8.8 axle girdle
Nope. For example, on page 61, 2/3 down the page, their posi units require c clip eliminators.
http://www.strangeengineering.net/catalog/index.html
I was considering 33 splines for mine, actually, but settled with my 31's.
