Does anyone know which valve springs or what spring rate is recommended for the Ford B-cam? Also, does anyone know what the installed spring height/spring pressures should be for e7's?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
the ford racing a-50 springs and b-50 retainers are what you need, it'll tell you installed height, but more so I'd go off of seat pressure as that's the goal then check for coil bind and so forth after
__________________
Quote:
Originally Posted by dudeboy
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
If you wanna go more high tech, comp Beehives. They're standard on the GM LS7 and all of Edelbrocks XT series heads(and I think all of their crate engines now). It'll give you a lighter valvetrain that's more stable at high rpm, but the matching Ford stuff will be fine as well.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
