Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-08-2009, 12:53 PM   #1
gt884me
gt884me's Avatar
Vehicle: 1988 GT
Default Stock pushrod length
What is it?.....Is it 6.25? I need about .100 longer, what size is that 6.35?....Thanks
__________________
1988GT, Stroked 347, AFR 165s, BBK SSI, Comp XE270HR Cam, All the Bells And Whistles
gt884me is offline   Reply With Quote
Old 08-08-2009, 12:59 PM   #2
OnyxCobra
OnyxCobra's Avatar
Vehicle: '95 Mustang Cobra
Send a message via AIM to OnyxCobra
my stock length was 6.25"
__________________
CarDomain - OnyxCobra
OnyxCobra is offline   Reply With Quote
Old 08-08-2009, 06:09 PM   #3
sn95_331_GT_ yellow
1995 Ford Mustang
sn95_331_GT_ yellow's Avatar
Vehicle: 1995 Mustang GT
Send a message via AIM to sn95_331_GT_ yellow
yes, stock is 6.250".
make sure you not only measure the pushrod length, but look at the rollers tip sweep on the valve tip. it needs to be centered otherwise you will snap rocker studs. if push comes to shove, shorter is better than longer if you for some reason cant get the right length. also, you need hardened pushrods for guideplates (if you have stud rockers).
__________________
Canary Yellow 1995 Mustang GT
had bolt ons: wasnt fast enough, only beat LT1's.
357W build for about 3 weeks (436rwhp 402rwtq) taken out for my Factory Five '33 Hot Rod
baby boy due 20091203, cars kind of on the back burner (he's gonna help build it).
408W carb'd in the works (block and rotating kit already here).
sn95_331_GT_ yellow is offline   Reply With Quote
Old 08-08-2009, 08:37 PM   #4
67mustang302
Vehicle: 67 Mustang Coupe
Comp Magnums, they sell them in various sizes.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
67mustang302 is offline   Reply With Quote
Old 08-08-2009, 09:21 PM   #5
primetime5.0
Vehicle: 88 GT
get trick flow pushrods.. same as the comps only cheaper
__________________
R.I.P. Robert H. Western
ported e7's and an e303 cam
primetime5.0 is offline   Reply With Quote
Old 08-08-2009, 10:58 PM   #6
gt884me
gt884me's Avatar
Vehicle: 1988 GT
Heres an update...ive got AFR 165s....1.6 r.r's..and hardened stock pushrods.....after some checking AFR says to get .100 over stock...obviously i know i need hardened...i took off rocker today and saw the rocker wearing above center on the spring.....ill get an adj.pushrod to verify...Thanks
__________________
Old 08-08-2009, 10:59 PM   #7
gt884me
gt884me's Avatar
Vehicle: 1988 GT
Anyone need some hardened stockers with about 100 miles on em?
__________________
Old 08-08-2009, 11:02 PM   #8
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
jamie, i may need some since i dont have hardneded. i dont know if the 66 heads will allow me stock length or not because the i know the deck deff isnt as high as your alluminum heads. so they may or may not work.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
2003, 347, 50, 635, ford, gt, knowledge, length, mustang, oe, push, pushrod, pushrods, rod, size, stock
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
