Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-14-2009, 02:32 PM   #1
John Brennan
1989 Ford Mustang
Vehicle: 1989, Ford Mustang GT
Default refill differential fluid??
i just finished up replacing my rear drums with discs but now i need to refill the diff fluid and im not 100% sure what to do. i know there should be a place to refill on top of the diff but i cant seem to find it and how do i know when i have put enough in? Also i read somewhere that LSDs take a "special" fluid and want to make sure i use the right one.
__________________
1989 gt
John Brennan is offline   Reply With Quote
Old 08-14-2009, 02:37 PM   #2
Tony71502
Tony71502's Avatar
Vehicle: 1991 Ford Mustang
Any differential with clutch packs in it requires friction modifier. It's a stinky ass fluid additive. One bottle will do. If you use the more expensive fluid like Royal Purple or Lucas, the modifier is already in it.
The fill plug is on the front side of the differential housing, above where the dogbone bo9lts on. Fill it until you can stick your finger in the hole and can touch the fluid. You can't really over fill it as it will end up spilling out. Basically it gets filled up to the hole.
It's right behind the yellow DOT approved tag.
If you have an aftermarket differential cover, you could fill it through that. But I bet you don't.
__________________
1991 LX 5.0 5Spd
Cobra 4 Wheel Discs/5 Lugs
Saleen SC Wheels w/ 255 Fronts, 275 Rears
Tremec T5
31 Spline Eaton Posi w/ 3.73s
MM Suspension
Stock 5.0 w/ B Cam, Long Tubes, and Pulleys
Dyno Numbers Pending Break In
Tony71502 is offline   Reply With Quote
Old 08-14-2009, 02:46 PM   #3
John Brennan
1989 Ford Mustang
thanks
__________________
1989 gt
Old 08-14-2009, 02:48 PM   #4
tohoopty
tohoopty's Avatar
Vehicle: 1987 coupe
make sure the car is level too when you fill it.
tohoopty is offline   Reply With Quote
1989, 2000, 31, cover, diff, differential, eaton, fluid, ford, gt, level, mustang, refill, spline, svo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
